You can't legally remove back seats and trims.
If it is to put in half cage (I.e.Brown Davis cams approved), it is legal but you have to get vicroads to change it to 2 seater.
you will need to register it as a 2 seater if you remove the seats. I believe its as easy as going to Vicroads to get it changed from 5 to 2.
However changing back from 2 to 5 is a bit harder as you need to get the seatbelts rechecked or something.
Hope that helps?
Hope that helps?
yeah that dose cheers,do you know do they need to inspect the car or is it more paper work stuff?
My experience with it is I could remove back seats though seat-belts and buckles must also be removed.
Had to be taken to VICroads for inspection that is all. I had sound deadener and rear trims removed. Said nothing.
VICROADS REGULATIONS
An Approval Certificate is not required if:
  • the number of original seating positions was less than 10
Nowhere does it say you have to remove belts or anything, but I would assume you would be doing this anyway.
Does not say it on VICroads website. I did it anyway and when I took car in he said they had to be removed. That was probably just his opinion as it doesn't say you have to so I gather you shouldn't have to as Aaron has said.
I just removed the seats and didn't do a thing. Not one cop has every said anything about it. The seats that is, they always bring up the fact its stripped.
Of course I never let passengers sit in the back.
Edited by Peter89
I drove around with a boot installation in replace of the back seats for a few years, and every time I got pulled over never had a problem.
Once a cop asked about the two seater status, and I had that Vic Roads rule ready and saved on my phone and he was fine once he saw that.
I even called Vic Roads to register it as a two seater once and the guy on the phone asked why I would bother and it doesn't matter or effect anything.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
