Do you know if that tape is available seperately Kym? Cause normal double sided tape will be too think and will buldge the surface if used...
Jason, did the group buy go ahead before... for some reason I thought you bought your set as a test before the group buy went ahead... Or was that the headlights? :) Or have I missed the boat on this one?
Brett - a friend of mines audio shop does them - im eventually going to get it done once all the performance gear is paid for n done ...... i'll get a price on them installed then if your still interested.
If you can confirm that it is the same set as the ones shown in the pics here I will be interested for sure. From the sounds of it I can probably do the installation myself so a price for just the guages would be great :)
Hey thanx for the nite shot CHAMPS!!! :wassup:
Got another question (might b a stupid one) but can the whole face luminates blue or green, not just the centre? And the numbers to obviously be more visible. :bs!: I doubt it but i thought i'd ask anyway. Can it?
Cheers :D
Well after an afternoon of hard work I am now a proud owner of a new set of guages....I am very pleased with the end result.... Thanks to everyone that offered advice and assistance :)
Kool. Where u get urs from MrGTST, wat type and for how much?
Cheers.
Cheers.
I got the same set as in the pics from evolution R in bentley for $140 ..... money well spent I think. I dont think they have access to many more sets though so if you are interested I would check them out sooner rather than later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
