  • Replies 285
The differences are enough to screw up cam timing but shouldn't be enough to cause valve/piston interference. I have a friend here that runs a shop and he swears up and down that he's done a few RB25DETs with RB26 cams and they have no issues. I'll give it a go soon. I have a wonderful Japanese comprehensive inspection first though 8(
  • 1 month later...
I've followed both strings on this mod , anyone have any idea why SK can get it to work and most others can't . What are the potential problems aside from bent cams/incorrect cam and CAS timing/cam journal cap bolts . In other words if the cams are exchanged with no dramas and the timing/s are the same its difficult to understand the idle problem . Nissan must have had the multi throttle system in mind with its anti reversion properties when they developed the RB26 profiles which would allow greater overlap period without the rough low speed / idle problems . I would have thought opening up the cams (reducing the overlap) would have got an acceptable idle ie enough trapping efficiency always assuming the valves closed . I guess a bit of reversion at the AFM could cause problems , does SK do anything different to all else here . Would larger capacity inlet ducting/MAF/IC/better filter make any difference .
Cheers A .
I think thats the million dollar question. From memory he was going to put together a tech article about installing RB26 cams but I don't think he ever got around to it.
I'm just guessing here, but I wonder if there are some subtle cam timing differences that are causing dificulties (eg setting an RB26 cam up using the RB20 timing marks etc might not put an RB26 cam at true 0 degrees, instead it might be advanced or retarded a bit). Who knows tho.
  • 5 months later...
one did but idle was the problem on standard ecu, would it be possible to idle it upto 1500rpm to make it stable??
A few weeks ago Turbine and I did this mod as I had the GTR cams I bought from Ronin7 and two adjustable cam gears I had enginered from the originals for $300.
We fitted the cams and had the same idling problem. Even setting them to 2000RPM would not have solved the problem. They sounded great though at 3-4K and strong. I think Turbine got a phone movie? Not sure.
Anyway had to pull them out the week after to go to the SAUVIC show so the car would be drivable.
Turbine says "oh well have to learn how to do it for the drag car"
Guess who ended up with the GTR cams and Adj Pulleys?!!
See my BLOG for more on this episode.
Forgetting the fact that ppl have had troubel getting ths to work...there isnt any really any solid info that you will actually make more power...so add the two up and i wouldnt bother with it.
Lukes01 i think it is offered to help me out and regrind my cams to suit, adn i was goign to take him up on it, but my cams went walk about so cant get them back...if you insist on tryign this, perhaps take a different tact and chase up Lukes01
Yes Turbox, the cams are in the race car now.
They are standard RB26DETT camshafts both set to zero on the adjustable drive gears.
I fitted the standard RB20DE hydraulic lifters and the standard RB20DE camshaft brackets.
At first I had the cams fitted with no lifters, to get a feel for how they rotated in the head. NO problems at all, smooth and free. So out they came, fitted the lifters back in and refit the cams.
I did apply high temp anti-seize to all of the bolts that mount the cams in. I found that theri was moisture getting into the bolt shanks somehow :confused:
It's interesting that SK mentions about cam timing on the RB's with these cams as a nominal +2IN, -4EX starting point.
This would explain the idle problems when both are set to zero. Moving the cams like the above mentioned actually reduces the valve overlap by 6 degrees total.
RB20's dont have alot of airflow below 2500RPM compared to the big RB26, so....... the horsepower gain could only be through the higher lift.
I'm going to try them at zero first up because i dont care if it idles at 2000RPM, the converter stalls at 5000RPM anyway. I'll let people know how this works out in time.
Turbine.
"It's interesting that SK mentions about cam timing on the RB's with these cams as a nominal +2IN, -4EX starting point.
This would explain the idle problems when both are set to zero. Moving the cams like the above mentioned actually reduces the valve overlap by 6 degrees total."
so your saying if you did this you might have a better chance of it idleing alittle better?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
