Hey i have done a search without alot of success.
I read in another thread sydneykid and Roy talking about installing standard RB26 cams into an RB20.
I just wanted to know more about it. who has done it. what changes to the head are necessary and what sort of gains seen from such a modification.
any info would be great.
Cheers!
https://www.sau.com.au/forums/topic/38857-rb26-camshafts-in-rb20/
  • Replies 285
1. who has done it
2. what changes to the head are necessary
3. what sort of gains seen from such a modification.
Hi Benny,
1. We have, 4 so far
2. None
3. Very much depends on what else you have done. But from what we have seen, you will get;
A. earlier boost build
B. faster throttle response
C. about 15 rwkw increase in the average power from 4,000 rpm to 7,000 rpm
D. about 10 rwkw increase in max power
If you are on a budget and can do it yourself it is very worthwhile. If you can't DIY then you may well be better off spending a few hundred extra on used aftermarket cams, as the fitting cost will be the same. As Autobarn suggested, there are a few HKS 264's around that are a step up from standard RB26 cams
Hope that helps
Thanks sydneykid.
hmmm well im always keen to try it myself. however i have never installed cams before. but it hasnt stoped me from doing everything else to my car :)
ill have to read up on it first. any advice?
is there a large price difference between step 1 HKS and GTR cams?
Thanks sydneykid.
Hi Benny, since used pairs of standard GTR cams are pretty common, I wouldn't pay more than $300. Used HKS (or any other Japanese brand name) cams seem to go for around $800 for the pair.
I am also keen on doing this,
SK - have you noticed any differance between R32/33/34 GTR cams? each one seems to come out with differant torque from the factory, just wondering if this is cam related or something else?
Seems like a really good mod, I assume there are further gains to be had with adjsutable cam pulleys as well? Any setting you can recommend to try?
Chris
Hi Chris, I haven't seen any difference between R32 and R33 GTR cams. The R34 exhaust cam has slightly different lobe centres, but it is pretty minor, most likely for emmissions anyway. Adjustable camshaft pulleys are worthwhile, if they fit your budget. I usually start at 2 degrees advanced on the inlet and 4 degrees retarded on the exhaust.
Hope that helps
Cheers, now just need to find a set and I'll be right! I will get some cam gears as well to optimise the whole setup
Thanks for the info, those pulley settings seem to be what everyone ends up at with RB26's, would those settings still apply for RB20? I guess the best test will be to install them and have a play on the dyno to see whats best, but I guess they will be a good starting point
Chris
thanks for the info Sydney kid, i am just getting a pair of adjustable cam gears, but i think i will add a pair of GTR cams to the trolley and see what results i get.
for everyone interested i will post the results before and after so we can see the true difference.
Oh and any advice when installing them?
Anyone know what the difference in specs between the RB20 and the RB26 cams are. Im guessing the RB26 have a longer duration as the HKS would but maybe not as much???
Cam timing is pretty much the same (240) but the lift on the standard RB26 cams is much higher (8.6 mm vs 7.8 mm). So you don't loose a lot down low, but the extra lift is great all through the rpm range. Most brands of aftermarket 264's are around 9.2 mm lift and, depending on the condition of the hydraulic lifters, this can be a problem. Plus you loose a bit down low because of the longer duration.
The standard RB26 camshafts into RB20's is a real good, cheap upgrade.
Whats the go with hydraulic lifters if your current ones are a bit tired. I have been given a price to service a head, lifters and all, but what is involved?
Ive got the cams, valvesprings and cam gears to go in, but if you have a slightly noisy lifter on startup... im imagining its time to do something about the lifters at the same time as the GTR cams go in. ... What started out a s a cheap/budget upgrade to try and fill the lungs of the TD06 a little earlier is slowly turning into a pricey build.
hmmm thats what i was afraid of roy, something simple and cheap(ish) getting all nasty on me!
have you done the cam instalation yourself? how difficult is it. the only thing im worried about is setting everything in alignment - top dead centre or whatever. i dont want to make a mess of things when i get it all going.
To take the head off and instalibng the cams isnt a real drama, doing it with the head in place holds a few challenges which means i may not be able to do it myslef...
plus with my new accomodationin i no longer have a suitable place to work on my car. The compression test on my engine next week, and a few things falling into place the next 24hrs will play a big role in whether i bother with my current engine, or start with a blank canvas.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
