, and a few things falling into place the next 24hrs will play a big role in whether i bother with my current engine, or start with a blank canvas.
Roy, the clinic just called. They've approved your application for "the operation". Have you asked Prank to change your nic to "Royette"?
  • Replies 285
I have swapped by RB20DET in cam for an RB20DE.
You need to get the timing belt off, which is real simple and explained on the forum and in the GTR manual in the forum, making sure that everything is at top dead centre which is easy coz there are markings on the timing comers and on the rear timing cover (behind the cam gears). When taking of the harmonic balancer you will need a 27mm (I think socket). FYI – it is a normal thread.
Take the cam cover off.
Take the cam gears off.
Take the rear timing cover off (the cover behind the cam gears).
Very gradually undo the bolts that hold the bridges that hold the cam gear down. Do this slowly and take your time. When I did it I got some crud caught in the brackets which made it very difficult to undo the bolts - I though that I had threaded the holes but it was all ok.
You will notice that the bridges are numbered. They go from one to seven (I think) front to back. There are also little bumps in them that tell you which is the right hand side. Clean them up and take a look before you take them off - remember not to get excited and rush it.
Once the cam is out you can put the new one in. You might like to get a new front seal as the old one may be a little stretched. I think I paid $30 each (one for each cam) from Nissan who had them in stock.
I had a problem whereby the crud in the bridges made the screws stuck in there and I could not turn them. Using a vice and a hold punch I managed to get them out.
Remember to crew the cam in gradually when putting it back in. When I did mine I used the torque settings in the GTR manual which saw me snap one of the bolts. Once I got it back out again I simply screwed them down tight.
Put it back together ensuring everything is at top dead centre.
FYI the exhaust cam has a little something extra in the end of it which drives the crank angle sensor which the in cam does not have (this will help you to identify it if you mix them up).
I have tried to be brief. If you would like me to describe something in more detail let me know. Also look on the forum for the GTR manual. It has pictures.
Roy, you said doing it with the head on holds a few more challanges... why do you think so?
I would have thought taking the head off would be more difficult as you have more things to take off and be more careful with.
Only bonus is you can change your gasket, maybe do some porting and check out the condition of your pistons(not that youll see all that much... )
Dont have to, just thought i would, std springs are fine, my valvetrain is getting a little long in the tooth, so though some fresh valvesprings will help when i wind 1.4bar into the old girl (There she blows!)
My uinderstanding is the valves themselves will fall into the combustion chamber if you remove the valvesprings and associated valvetrain.
i wouldnt take your springs off without takin your head off, unless your pretty good. and puttin the collets back in would be fun with the head on, as you wouldnt be able to hold the valve up
It's the thicker white mark. If you are unsure, there are also timing marks on the cam gears and rear timing case cover. You can use them instead of the marks on the crank pulley.
I don't think that I would be able to do the job with-out removing the radiator.
Hey Waz,
Not alot happening at this stage as i had to fork out for new brake rotors just yesterday and decided to get some DBA 4000. very nice i might add, but this means the cam and cam/gear purchase has been put on hold. hopefully i will get around to it in the next week or two.
has anyone else started yet?
i managed to download the R32 GTR manual in PDF form, excellent help, i have printed out the relevant pages. it doesnt look like a difficult job, just alot of crap needs removing in order to get to the camshafts. what sux is having to drain the radiator and pull it out. its a fiddly job to do at home, looks like it will take a whole saturday to do properly
Roy,
You said you were looking at valve springs.
You wouldn't have a price on them would u? just off the top of your head.
I'm going to do valve springs to suit the cams later downt he track. BUT the price for a set of valve springs I got was up around the $700 mark.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
