Cams and cam gears are in... only thing is i need someone i Melb that has a blown RB20 that i can steal some parts off.
I need the cap for cylinder no.6 on the inlet cam...as one of the stud has siezed in the aluminium cap, i was lucky to get it unbolted from the head without snapping or seizing...
Anyone in Melb able to help me out, or know of a friend/workshop that can help me without woth one (will need thw two stude that go with it as well.
hey Roy, i had the same problem when i put a new head on my rb20... i just pressed the bolts out, and then buffed the on a wire wheel, and saoked the caps in subaru upper engine cleaner... gets rid of the carbon good wink.gif (helps when you work at a subaru dealership)
  • Replies 285
yeah basically anything aftermarket that allows you to play with ignition timing and fuel you should be sweet.
unfortunately im too poor now :(
i was going to suggest maybe the IAC (idle air Control) valve, becuase at idle, you throttle is not open at all, and if the IAC isnt open enough, or slowly closing, it wont idle, but as soon as you open the throttle, it would be fine....so it probably is the cams that are causing the problem, via the IAC valve, if that makes any sense
I tried tapping it out, i tried heating (different expansion rates of alloy - steel), i tried soaking in WD40 overniht, this puppy will not budge. When i was removing it, the mroe i turned it the more it bound up. By the time i got it off it was next to impossible to even turn. Im assuming the metals have galled, so goodbye to ever using it again.
As for ecu, mine is a re-written std one which going by the colour of the plugs runs pretty lean. Im not too worried about getting it to idle, worst car scenario ill tighten up the throttle cable to get an 1100rpm idle. Its getting tuned as soon as i am able to fix this cap.
Walked to work today!!!! I need to thrash my car around a circuit so that i can remind myself what all this agro is for.... the install was a piece of piss as well, right up to the last cap... a little uipset that such a silly little prob is stopping it all going back together.... always happens this way though
yeah, well as i was sayin roy, if you have access to a press, you can get them out easy.... put a 10mm deep socket on the cap bolt, turn it upside down, and put another bokt or a pin punch on the tip of the siezed bolt, and press it out... took about 5 tons to press mine out... then just clean up inside the cap with ultra fine wet n dry and a bit of upper engine cleaner
Can someone answer my earlier question plz?
Camshafts from rb26 should be able to go into a red top rb20?
regardless of the age of the engine ..... i'd imagine it would be similar to the silver top head
at the moment i'm saving up my pennys for a BIG upgrade next year .... with Wolf3d and gt2530 turbo ..... hopefully with gtr parts as well ... jsut want to finalize what i can buy ...IF i can buy that is
Thanks guys
Matt
Based on the pioneer work some of the guys like bbenny etc have doen trying this (well on SAU anyway) i dotn think you will get anyone to confirm that you can used them ont hered top engine.... i suspect you will be right, but wont hurt to buy some cams and give it a try, you will lose an afternoon trying, and if they dont fit then you can easily sell them and get your money back.... just dont snap a stud or seize a stud int he journal and its a free exercise trying:)
Well scratch up another that couldnt get the thing to idle, and then afer a bit couldnt even get it to run.
I tried a bucket load of things to get right, biggest thing couldnt get the thing to fire after a while , but car will be at mechanics tomorrow getting tuned / fixed...pending getting my hands on a PFC ill be able to post up some figures, and hopefully have a car that will idle and drive nice.
Thanks to bbenny, Doughboy and 46n2 for their help, corruption and advice (in no particular order)
Ive got an aftermarket turbo, bigger injectors, adjustable cam gears, R33 Series II AFM and re-written Jap ECU... so the re-writen ECU and bigger injectors were going to either help me or hinder me more then bbenny with the std ECU and injectors.... it turned out to be more a hindrance it appears.
Hmmmmm........ well at least it looks like everyone is having no probs with the installation as such, just the nature of the ecu stopping the whole thing from working
Will be interesting to see how it goes with the PFC Roy
cool good luck...
mine goes into the experts on thursday and i have already spoken to them about the possibility of idling problems and they said the only bad thing would be lumpy idle, not idling problems - unless it was too lumpy to idle, but with only mild increase in lift it should be fine apparently (said by mechanic)
Hi Benny,
1. We have, 4 so far
2. None
3. Very much depends on what else you have done.  But from what we have seen, you will get;
A. earlier boost build
B. faster throttle response
C. about 15 rwkw increase in the average power from 4,000 rpm to 7,000 rpm
D. about 10 rwkw increase in max power
If you are on a budget and can do it yourself it is very worthwhile.  If you can't DIY then you may well be better off spending a few hundred extra on used aftermarket cams, as the fitting cost will be the same.  As Autobarn suggested, there are a few HKS 264's around that are a step up from standard RB26 cams
Hope that helps
Would you please explain how you would benefit from GTR cams in an RB20, when RB20DET cams have a duration of 247/8 degrees and HYDRAULIC LIFTERS and GTR cams have a duration of 240 and SOLID LIFTERS.
It's my understanding solid lifter cams won't work in hydraulic lifter engines as the profile shape is different.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
