I just put 33 GTR cams in, takes about 30 seconds to start and idles just like that video of the maroon S13 only hunting up and down with the idle screw almost all the way out. But seeing as all the hard work of removing my rusted on harmonic balancer and seized cam caps, it's not that bad to pull it apart again to chuck some RB25de cams in I have lying around. I may even mix and match the RB20 exhaust cam with the RB25de inlet cam as they have different lobe separations
  • Replies 285
sounds like all that happens is you get lots of boost/fuel blown out the exhaust ports at low revs and high revs its only slightly better from what I've read.
I would put money that the average power has actually gone down.
  • 2 years later...
rather than making a new thread that's kind of on the same topic.
I want to buy a set of used R32 GTR cams (but don't want to get screwed over). Is there anyway to tell that they are R32 GTR cams? Do they have particular markings so you would be able to tell the difference to say a set of RB20 cams or other cams?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
