  • Replies 285
Update on installation:
All going well till about 8pm last night when i snapped one of the damn clamp bolts into the head! there is a noticable size difference between the GTR and standard cams, so ill be interested to see how it goes.
Hopefully i can get this broken bolt out thismorn and find a replacement.
I have decided against adj cam gears as i beleive i will need bigger injectors after installing these cams and winding some boost in.
I will post "seat-of-the-pants" results later today, and hope to get a dyno run, either tomorrow or early next week.
I just wanna make sure of something b4 i purchase my cams...
Does/ or should i say Can this mod apply to ALL rb20's?
i'm just not aware of any apparent differences the red top head and the silver top have... if any at all.
Hopefully so.. it will go nicely with the gtr fuel pump and injectors i have ready to go with.
Thanks.
hows it all going bbenny? I am getting very toey now, can't wait. Got my S/S exhaust manifold the other day as well, so the puzzle is nearing completion
Microtech LT-12S then time to fit it all up, and add about 18-20psi boost :)
Chris
Thanks.
Hopefully SK reads this, he might have a better idea............
Well im need of urgent advice.
I have installed the cams and when i started the car it was fairly lumpy then the idle rmp drops and the engine dies out.
Now when i start the car, it just immediately dies out!
anyone got any ideas whats going on? Sydneykid?
thanks!
nope dont have a timing light, planned on taking it to the workshop in the morn.
i did refit the CAS in the marked area it was before.
should i try turning it lightly just to see if i can get it to stay awake to at least limp it to the workshop?
Hi BBENNY, I takes a while for the ECU to learn the new airflow requirements. An ECU reset might help as well. Does it run OK? If you open the throttle a little, does it keep running? Make any noises? Starts OK? No hydraulic tappet noises? Backfiring?
If that all checks out, take it for a drive. Any damage is already done anyway.
it runs fine when i give it some throttle, i havent driven it yet, but it wont hold idle no matter what position the CAS is at, it dies out pretty soon.
sometimes it starts, but most of the time it will turn over a few times then die out straight away.
there are no strange noises, infact it sounds pretty sexy with a bit of throttle :rant:
How do i reset the ECU?
any luck bbenny?
just curious, in a car fitted with a PFC if you reset the ecu, you loose the whole tune. So is it really necessary to reset it?
I understand it will probably need another tune for it to run efficiently but i thought it would be a in/out process. just a better flowing head.
yeah i think its more than just ECU, i noticed once the cams were installed that i could turn the ex cam very easily to adjust it to no1 TDC, however the in. cam was very stiff to turn in comparison, so just to double check i threw the standard cam back into position and if felt just as stiff...
i think my problem stems from the inlet cam being very difficult to turn over and that causing the engine to stall at idle.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
