yeah i tried all that Ben and Joel,
I just took it around the block then and it drives ok, feels a bit sluggish down low but starts to go hard by about 4000rpm, but i dont want to take it to high RPM or drive it too much just incase... but i drives, but will not hold idle.
  • Replies 285
HEY bbenny
just a thought but in the process of taking it all apart you may have accidently disconnected 1 or a few vacuum hoses...i know when i was mucking around puting in a catch can i knocked a vacuum hose and it did the same thing...idle would drop then die....similar to when you have a stock RB20DET and disconnect the plumb back pipe from the BOV
just a thought..maybe check all ther hoses
Aaron
Wierd?? sounds like a vacum leak, or something like that. Is your vacum lines hooked up to your BOV? Might pay to get a timing light and check the timing??
Does it blow alot of black smoke out of the exhaust at idle? That is a sure sign of a vacum leak.........
i played with the idle, but no adjustments made any difference.
i did pull the throttle body off for the installation but i dont think that would be the cause.
It runs fine when you give it some throttle.
the only thing i see responsible is the stiff in. cam...
i have tried just about everything else there is!
does seem odd, thats why I thought of the throttle, maybe its not open enough under idle or something? could explain why its running fine when the throttle is open a little? just a thought, as other wise I have no idea mate, sorry
You checked base timing yet? what is that set to?
I can't really see how a cam that is harder to turn (but is also is just as hard when the stock cam is in place) would be the culprit
well it was noticably harder to turn...
but then again that could be due to some of the lobes compressing a valve or two...
I can only point to a few possibilities - either the in. cam is not turning free enough, as we have discussed.
or the posibility that the timing belt jumped a tooth when i started the engine
however i did turn the engine manualy 3 revolutions and check the timing marks on crank and cam pulleys...
Its frustrating!
I will disasemble the whole damn thing again and see if i find anything.
Yep i think it is.
Ive decided to bail on the cams as i just cant afford aftermarket management.
otherwise it would be one kick-ass upgrade, i mean 25rwkw average increase for $300 is pretty damn impressive!
so im a little dissapointed i cant pull it off with the std ecu
i can confirm it is the ECU flysky. because i checked and tried everything, there were no other causes.
and SydneyKid has done several running a PFC with no problems and considerable gains.
no probs with standard cams joel
Cams and cam gears are in... only thing is i need someone i Melb that has a blown RB20 that i can steal some parts off.
I need the cap for cylinder no.6 on the inlet cam...as one of the stud has siezed in the aluminium cap, i was lucky to get it unbolted from the head without snapping or seizing...
Anyone in Melb able to help me out, or know of a friend/workshop that can help me without woth one (will need thw two stude that go with it as well.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
