Hey guys, decided not to go ahead with the project and now must sell my engine package.
This motor was in my mates S13 until he crashed it 6 Months ago and I was going to put it in my Datsun.
Engine was only ever tuned up to 14psi as the original owner was a novice driver.
This motor is 100% and I have receipts to prove everything. I also have a short video of the engine running last week and pics of the comp test showing an even 151-154 across all 4 cylinders. Please send me your email for pics of the comp test and video.
Its been very reliable and will be good for many years to come.
S13 SR20DET
JE Pistons
Spool Rods
Crack Tested, Reground and Nitrite Crank
Race Series Rings and Bearings
Block has been bored and honed, acid dipped etc
Bottom end Balanced
Head has been acid dipped, bead blast, machined valves and seats, pressure tested and milled.
All seals and bearings where replaced during rebuild. Timing chain and tensioner were also replaced.
HKS GT28RS Turbo - Very good condition
Stainless Steel High Mount Manifold with 10mm flange.
JDM S15 480cc Injectors
Microtech LT10s and ignition computer with full loom.
Splitfire Coils
Fresh Excedy Sports Tuff Clutch Kit
S14 SR20DET Gearbox with CUSCO Shift
Tuned by CMR Performance
Even Comp Test - Performed on the 12th of January 2012
Engine was originally built 3 years ago but has only seen 8000kms.
Engine Produces 217 rwkw on only 14 psi but will do much more with retune and boost increase.
Price for everything - $5400 firm
Postage available at buyers expense...
Located in South Sydney - Near Sutherland.
I may part out the package only if someone buys the long motor first for $2900. (Long motor means no manifolds or accessories etc. Rocker cover down to the sump)
Serious buyers can call me on 0415334551 between 9:30 am and 9pm.
post-51468-0-25185300-1326800717_thumb.jpgpost-51468-0-77971000-1326800718_thumb.jpgpost-51468-0-74097800-1326800715_thumb.jpgpost-51468-0-90736500-1326800713_thumb.jpgpost-51468-0-70991200-1326800711_thumb.jpgpost-51468-0-91332600-1326800709_thumb.jpgpost-51468-0-69744100-1326800707_thumb.jpgpost-51468-0-84861600-1326800705_thumb.jpgpost-51468-0-80374900-1326800703_thumb.jpgpost-51468-0-87505200-1326800701_thumb.jpg
https://www.sau.com.au/forums/topic/388577-built-sr20det-engine-package/
  • 1 month later...
