  • Replies 43
When you're tuning you hold on every cell to see what's happening then make adjustments. Doesn't matter how long it takes the exhaust gas to travel as you adjust by cell on constant load. Unless you're a wizz and can make changes in less than 3 seconds. (some tuners would have you believe they can)By the way, 3 seconds ? Ahh, NO. Only if at boost you have a 25mm exhaust.
Learn to tune your own car so you tune for every day over a period of time rather than the hour your car is on the dyno. The weather changes, fuel, heat and engine condition. If your motor blows it may be that these conditions changed and the tuner actually got it right only at the time it was tuned. I think Nismoid is about to tell you how rediculous worrying about the time frame of the exhaust travel is. Shhhh, here he comes, let's see if I'm right. :yes:
This is why I run my wideband in my tail pipe. If the tuner likes, they can compare the ratio with what they are getting at the muffler but surely most would know there is some delay from what just came out of the manifold to what is being shown at the tail pipe...
Havent you seen the tailpipe squiggle lines on Initial D and Wangan? That means the gas is travelling very fast.
3 seconds would not translate to squiggle lines IMHO.
Well if Motec and Ford seemed to think it was enough of an issue to measure it and adjust their tuning to suit, then I'm going to guess it isn't ridiculous.
There goes all credibility right there.
It wouldn't be the hardest thing to calculate a rough figure of the time if some one knew how to do it for a turbocharged engine.
Going off of very rough calculations I did with simple figures for a NA engine (2.5L engine at 1000RPM) I get around 4m/s out of a 3" exhaust - so around 1 second of travel.
That's just using some basic engineering formulas I can remember.
Would love to see some one elses complete working equations on it though, would be quite interesting.
I'm just not 100% sure on how above atmospheric pressure (boost) effects the formulas with an exhaust housing slowing down the airflow?
Just because one person at a company says something that doesnt make it the official company policy/opinion.
But it gives some credibility to asking the question and doing testing to see what the result is, it also doesn't give you guys a reason to be cocks about it.
Furthermore, does this mean most of us now need to go and retune our cars as were probably tuned 3 seconds out?
Does this also mean I will shave 3 seconds from my 0-100?
That would mean some of us will be defying physics.
You should start a thread about defying physics.
Would be curious to hear STATUS' opinion on this.
trent tunes cars with both methods. depends on the application... he said it makes fuckall difference :)
No but I would suggest you get a class in english comprehension : p
So I can impress people on forums. I'll get right on that.
Then I'll use my 'new found' literary skills and talk about reinventing the wheel on SAU. :wave:
    • I clean my wheels every time I was the car, I also clean the barrels, the only product I use on the wheels is truck wash, followed by wash and wax, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, there also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
