    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
