The Shannons Insurance Skyline Nationals 2012 - Goulburn And Wakefield Park
Results for the track day.
Now.
From here > http://classicskylin...msg9625#msg9625
Anyone know the Show and Shine rusults ????, the black 31 2 door with the cage was my pick !!!!
  • Replies 158
Bob, you won something :)
Can't remember what, but I'm sure they'll put up results somewhere.
OK........ Cool.. Thanks for that.
I haven't heard anything though.
Bob.
Bob.
Yeah, was all handed out at the Dinner. Unfortunatly a lot of the people from the S&S had shot though by then.
Was great seeing both your cars together. If you didn't catch the Guy who judged the ADM, and want that chat, you can PM on SAU under "jetwreck"
Without stating the obvious, not yet. We need to put them up here, and I don't have them, and have been at Sandown all weekend with the DR30.
However, if you had of come to the dinner, you would have known a week ago :D
Just a note on the sprint classes. Dennis has been moved across to class D and the results amended. That was done a couple of days ago when it was pointed out to me but the results are on the same link as before.
The remainder had to be checked out by myself while I dropped a sprint run to try to spot every car to check on classes. Most cars which were registered and driven to the day would have not ended up in race class, Fatz cause it is Fatz! Plus he and Jenna have been tracking that car pretty hard for a couple of years. I think Dennis is one of two cars I did not manage to spot while walking around.
The regularity results are up on the same forum link with the rest of the sprint results. To explain them, the regularity is scored by the standard deviation calculated in Excel between your three fastest laps of the day, so every driver who did at least three timed laps on the day went in the regularity, the closer together your fastest three the smaller your standard deviation and the better you do. A small club I am part of has been doing it's whole championship like that for years as we have about six regular competing members in five very different cars and the regularity format takes the car out of the picture while still not having to do anything but drive it as hard or as gently as you want.
GTR32G, just to put in another apology, I actually was expecting you to move up behind me pretty quickly and was looking for you, but between us we managed to time you moving across with me changing mirrors as I was starting to move towards the kink and I lost sight of you entirely as you went into a blind spot (Between the cage and helmet and driving position (Very very low, the windows are at my shoulder) the blind spots are not small) Just glad that there was no damage done, not what I want to see happen at a track day and certainly nothing I want to find myself involved in.
I also want to put up a thank you to everyone who helped on the day and everyone who entered, Given the format of the day (With Group A/C demos and or passenger laps between each timed run) I think that five timed runs of 12 mins plus two passenger sessions at the end of the day is not bad going. on a normal day without the historics there we would probably have had seven timed runs for the day.
Edited by Blue
Here is a HUGE word Doc with winners of the show and shine.
No doubt i will be making a smaller version and adding more photos to it as soon as i can.
And adding the missing categories
http://sdrv.ms/RdUmbx
  • 2 months later...
Gday, I"m wondering if the trophy for the show and shine were ever sent out ?
999 AutoShop Best R33 Modified winner – AL.62.VB
Thanks, Mark
I have your trophy sitting on my Desk, we had the rego number, but not the info for the car. can you please email [email protected], and I will get it sent out to you. Yours was only 1 of 2, of the over 100 trophies we gave out that is still to find a home. Congrats on the win, and I am looking forward to sending your Gold medal out.
  • 1 year later...
  • 1 month later...
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
