Hey guys,
I've just spent a few hours searching the forums for answers and can't find a definite answer.
I have an early model Cefiro RB20DET Auto from 1988. Currently it has a stock Auto Cefiro ECU, so all is good.
What I want to know, is the R32 Auto ECU a direct swap for the Cefiro Auto ECU? From what I've gathered, wires (pinouts) may be different... Is this true, anybody know for sure?
I'm asking because I'm about to do a remap using a NIStune board, and its developers have told me they are having trouble with Ceffy ECUs. They said the best thing to do would be to swap it over for a R32 ECU and go from there.
I was always under the impression the ECUs aren't a straight swap.
Thanks for any help
https://www.sau.com.au/forums/topic/388635-cefiro-auto-ecu/
  • 5 weeks later...
Hi iI have an Cefiro A31 RB20DET, Chipped ECU, For Sale, The new chip was done by Apet Facing and wow what a difference it made to my Cefiro after road testing it i came straight home and turned the timing back a bit as it had that much more power it freaked me out as its was loose as, The only other mods it had were pod filter and better coil setup, I have the spec sheet on what was done to the chip that was fitted if any body is interest the ECU owes me $400 NZ Dollars, Just Email me Thanks Jmind
https://www.sau.com.au/forums/topic/388635-cefiro-auto-ecu/#findComment-6243174
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
