Hey guys,
I've just spent a few hours searching the forums for answers and can't find a definite answer.
I have an early model Cefiro RB20DET Auto from 1988. Currently it has a stock Auto Cefiro ECU, so all is good.
What I want to know, is the R32 Auto ECU a direct swap for the Cefiro Auto ECU? From what I've gathered, wires (pinouts) may be different... Is this true, anybody know for sure?
I'm asking because I'm about to do a remap using a NIStune board, and its developers have told me they are having trouble with Ceffy ECUs. They said the best thing to do would be to swap it over for a R32 ECU and go from there.
I was always under the impression the ECUs aren't a straight swap.
Thanks for any help
https://www.sau.com.au/forums/topic/388635-cefiro-auto-ecu/
  • 5 weeks later...
Hi iI have an Cefiro A31 RB20DET, Chipped ECU, For Sale, The new chip was done by Apet Facing and wow what a difference it made to my Cefiro after road testing it i came straight home and turned the timing back a bit as it had that much more power it freaked me out as its was loose as, The only other mods it had were pod filter and better coil setup, I have the spec sheet on what was done to the chip that was fitted if any body is interest the ECU owes me $400 NZ Dollars, Just Email me Thanks Jmind
https://www.sau.com.au/forums/topic/388635-cefiro-auto-ecu/#findComment-6243174
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
