My 1994 V-Spec II N1
Many Thanks go to...
* JLM for sourcing this specimen and having it inspected; but also using a bidding ploy to secure a winning bid.
* Iron Chef for acceding to JLM's request for one of Kristian's team on the ground to inspect this car before auction.
* Aussie_Delivered_R32_GTR for sourcing a perfect condition steering wheel, Blitz DSBC, Bilstein shocks, Nissan OK sticker
* Wongy for sourcing 'Old Style' Genuine Nismo floor mats via GTROC and Newera Parts
* Luke_GTR for sourcing 'Old Style' Nismo radiator cap
* JLM for sourcing 'Old Style' Nismo oil cap and Nismo key holder
* Count Grantleyish for sourcing 'Old Style' Nismo seat belt pads
* Aggroman for sourcing 'Old Style' Nismo kill switch lighter
* Kudos for Nismo brake lines and clutch lines and Nismo fuel pressure regulator
* Sean_GTR for Nismo 555cc fuel injectors
* iwantr34gtr for Nismo fuel pump
* NURVOUS for Nismo fuel cap
* lochilea for Nismo LMGT1 18x10" wheels
* kamikaze for Nismo LMGT1 18x9.5" wheels
* Redline_GTR for sourcing N1 decals (albeit R34 GTR design)
* mxfly for an expert detail and Fujimura front splitter
* Just Jap for HKS Silent Power 80mm exhaust and air diversion plate and KPGC110 grille badge and 'Old Style' Nismo badges
* Andrew Sullivan for 'Old Style' Nismo boot sticker
* Redline_GTR for 'Old Style' Nismo strut brace sticker
* Drewr for HKS gauge pod with gauges
* deongster for wiring and sensors for the HKS gauges
* DBA for T3 Series 4000 F&R brake rotors
* Bridgestone Select Blacktown for new tyres
* Carbon Car Systems Blactown for security system
* Steve's Auto Barn Blackheath for wheel alignment
* SAUers (I've forgotten sorry) for D-Spec clear indicator lenses, Tomei sump baffle kit, Nismo castor rods, 'Old Style' Nismo horn button
* GT-R Magazine for doing a photoshoot stitched up by JLM > Issue #120 January 2015
  • Like 4
  • 4 weeks later...
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
