COMPRESSOR:
-Wheel- 46 Trim - 51.7 Inducer / 76.2 Major
-Housing- 60 Inlet / 50 Outlet - 0.50 A/R
TURBINE:
-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer
the unit has done 10k..would this be a good upgrade..i have the usual other bolt ons...what charecter-istics would this turbo have on an rb20det..thanks ion advance
https://www.sau.com.au/forums/topic/38869-hks-2540r-on-rb20what-you-think/
i have a 2530 on my RB20, i heard to many stories about the 2540 being too laggy on an RB20.
The 2530 maybe a little laggier reaching 1bar a couple of hundred revs later than the standard item, but mid range is strong and top end difference is awesome.
at the moment im running std computer, untuned. and its putting out 210rwkw at only 0.9 bar. i havent wound the boost up as over 1bar the engine cuts (maxing out AFM i think).
im in the process of getting some GTR cams and adj cam gears to see the difference then get the ECU tuned. i hope to get about 230rwkw, any more and ill be stolked.
I just think that the 2540 would be too laggy. if people are complaining about lag on an RB25 i dont want to know about it on an RB20.
beario, GT2540R has a T25 flange.
if you want it to bolt-on to your standard rb20det manifold you are going to want the GT2540.
2540R only has about 20ps over the 2540 anyway.
more info: http://www.hksusa.com/categories/?id=1092
gees guys i have bought this turbo now...as no one replied to the thread straight away...so your saying the turbo wont bolt on to my standard rb20det manifold..??and there is going to be massive lag...someone please give me some charecteristics of this turbo on the rb20det...can i have the manifold modified so it fits easily or have i just wasted a BUNCH of money..... :(;)
gees guys i have bought this turbo now...as no one replied to the thread straight away...so your saying the turbo wont bolt on to my standard rb20det manifold..??and there is going to be massive lag...someone please give me some charecteristics of this turbo on the rb20det...can i have the manifold modified so it fits easily or have i just wasted a BUNCH of money..... :(  ;)
Hi beario, you post this question at 1 in the morning, get a reply at 2 in the morning and complain about no one replying straight away. That's a bit harsh. Plus if you had bothered to do a search on 2540's you would have read all that you needed to know.
To answer your question, you can get a bolt on adaptor to fit the T25 flange to the T3 manifold. Your local turbo shop should have them. Or you can buy a T3 exhaust housing for the 2540. Either way, in my opinion, you have a 2540 that has too big a compressor stage for a light tune RB20.
Hope that helps
sorry sydney was not having a go...all help was greatly appreiciated...i guess now its bought i had might aswell put it on,and see what its like...in your opinion where will the boost come in...my mods are hks evc,3 inch front pipe,4 inch cat back exhaust,hks air filter,super afc,mines ecu,ported manifold(intake de burred)...will the boost be gradual or all or nothing..thanks
It's a 2540, so it will show all the usual 2540 results. It will have nothing under 3,750 rpm. and go to full boost in less than 1,000 rpm. It will hold 19 psi from there to 6,250 rpm where the boost will slowly taper off to around 15 psi at 8,250 rpm. The slow boost build and rapid transition is because of the large compressor. The drop off in boost is because of the small turbine. It's the standard 2540 missmatch between compressor and turbine.
My suggestions would be;
1. a pair of standard RB26 camshafts, the higher lift will help the response.
2. something to tune the ignition timing, you have fuel correction (SAFC) but no ignition control. This is the most important weapon you have for improving the response.
3. FMIC, you are going to have severe restriction with the standard IC. I would use an R33/34 standard GTR intercooler and keep the pipework short via a 120 degree bend at the throttle body. Use 63 mm pipe from the turbo to the intercooler and 75 mm form the intercooler to the throttle body.
4. A pair of adj camshaft pulleys will also help
Hope that helps
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
