Hi guys,
I am in the process of getting a single turbo and am looking to get some boost into the vq.
I'm hoping to be able to run 10-15 psi. I am looking at buying the following.
Turbo kit (unsure which yet but want a single)
Larger injectors
Larger fuel pump
Stronger rods
Lower comp pistons
New button type clutch
And a up rev tune
Does anyone know if I will need any more internal mods or will this suffice.
Any help is greatly appreciated.
Will post up pics of build once it begins
Sooooooooo can't wait.
https://www.sau.com.au/forums/topic/388701-vq-build/
Hi guys,
Larger injectors
Larger fuel pump
Stronger rods
Lower comp pistons
And a up rev tune
Kind of depends on what power your aiming at? rods are the VQ weak point and a set of low comp forged pistons are also good, whether you will need more will depend on your BHP goals, i am not sure if the valve material is up to turbo combustion temps?
One other thing you will definitely need is a complete fuel return system as the VQ doesn't use one, a decent adjustable fuel regulator as well, how are you planning on coupling one turbo to two headders?
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6194328
I have a spare set of VQ25det manifolds here if you are interested, Single turbo and bolts up to the VQ35, same manifolds HKS used...
I can even help with the turbo and fabrication work seeing you are local, PM me if you are interested.
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6194341
No worries sorry dude just moved to Perth. Haven't changed it yet. Not sure of goals to be honest was thinking if I can get to that boost safely I'll se what happens. Then I don't have to open the top end up. Something else to play with later lol.
I was just gonna buy a bolt on kit with everything.
If u can help with fab I'd be happy to try price it all up and pay postage tho.
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6194357
Too late for me to look for post but i wrote all the info on what you will need and approx cost for ST to get 450-500RWHP
P.S Cobey is selling his complete HKS 3037 Turbo kit with fuel pump, gauges...
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6194438
No worries. If u find it let me know I have done a search but must be looking for the wrong thing.
I saw that kit. Just need to sort out the dollars and I'll prob make an offer I think.
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6196293
Found it
I will list prices that are without shipping from the USA but are the cheapest prices just from looking around on the net.
As far as a built engine: Performance parts
Wiseco Pistons 96.0mm (+0.020" Over Bore) 8.5:1 + Rings $1150 (includes eagle rods)
Eagle H Beam Rods & ARP rod bolts $inc above
ACL Race Rod/Main/Thrust Washers & Washers $165
ARP Main studs $167
NGK Iridium one step cooler spark plugs $70
*Dont worry about forged crank shaft
OEM parts you will need
Welsch Plugs (can be reused i guess) $30
Rev up oil pump (can use old one but i upgraded) $190
Water pump (can be reused i guess) $46
Overhaul gasket set $250
2x Timing Chain $210
3 Tensioners + 2 guides (you could get away with old ones but you never want to have to replace this stuff once engine is back in) $230
HR Head studs * $58
HR Head gasket * $58
* You can save alot of money by going the HR head gasket and HR head bolt route, they are good for 600HP
http://www.jimwolfte..._HEAD_BOLTS.pdf
if you want ARP head studs then $175 or $400 for L19s. If you want Cosworth head gasket then $260
Machine work that you will need to do (and will cost between $1200-1500)
Head recon x2
Bore & Hone
Deck block
Chemical clean
Balancing
Crank regrind
Other stuff so you can include in budget if needed
Fuel pump DW 300ltr one (better than walbro) $170
DW injectors, 600 perfect for your goals $lots second hand for $350ish
Radiator - you will need a better one than stock Koyo Rad Vs Stock $350 + fans ($120)
Wideband gauge like Zeitronic ZT-2, maybe even oil temp/pressure gauge ($250-300ish)
EMS: Haltech is the best but $ and cost more in tune fees, i went with Utec as it popular in USA and good for 600HP (can do more but by then you spending big $ and can afford the Haltech)
Stopping power
Stoptech Stage 2 (slotted rotors, braided lines, motul rbf fluid) $860
Get a pair of used brembos from g35driver of my350z $800-1200 (if u have stock non brembos)
Save up for handling so you can use that 300rwkw
whiteline sway bars and upgraded end links $700-800
then bc racing br coilovers $1300
If you want contacts of where to get the cheapest stuff (cheaper than prices i found displayed online) then let me know, trust me i researched the shit out of it, spoke to many vendors in the states, that list is countless hours of research...
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6197036
Found it
ARP Main studs $167
HR Head studs * $58
Head recon x2
Bore & Hone
Deck block
Chemical clean
Balancing
Crank regrind
Stopping power
Great write up as I will be embarking on my engine build this year. Quick question, I've already got all the ancillary stuff in place and I'm currently looking at a clutch/flywheel combo to suit and then I will have everything in place ready for the extra power. You seem to have done a lot of research already so what would you recommend?
Aaron
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6198837
Aaron
If your going to do clutch then what i researched was:
Part Number: 6072-2100
Street Series 2100 Clutch Kit. Stage 2 - Steelback Brass Plus Clutch Kit
Part Number: 2-350Z-ST
Forged Lightweight Steel Flywheel
FW Weight: 18.65lbs (SOME ARE LIKE 8-13LB which is too light and will give you chatter, this one close to stock as possible)
Reason i went Competition Clutch was due to their high torque and HP factor (550-600?) and close to stock as possible.
I didnt get them from here but this is the ones
http://my350z.com/fo...best-deals.html
Make sure you also get
New Slave cylinder
Alignment tool
Stainless braided clutch line
Pilot Bushing
Chromoly pivot ball
Edited by R6n350GT
https://www.sau.com.au/forums/topic/388701-vq-build/#findComment-6199449
  • 4 weeks later...
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it    Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher      I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
