Hi Guys, got a few things to move on, all located in Brisbane, prefer pick up for the larger items,
Brand new Whiteline R34 rear blade adjustable sway bar, 24mm thick - $200
R34 bootlid tail light - perfect working order - $30
Stock R34 gtt suspension, Some leaking shocks, springs are fine - $50
R34 gtt neo engine cover and bracket - $70
R34 gtt stock triple gauge cluster with blue backlight conversion - $75
Various stickers - $5 each
PM or contact Steve on 0430 221 911
Hey have you got the part number for the swaybar? Just asking as it looks more like the front sway in the pics.
Hey mate, it is infact a front and not a rear, i'll amend the first post.
EDIT: Ok so i can't edit the first post for some reason.
THE WHITELINE SWAY BAR IS IN FACT A FRONT SWAY BAR AND NOT A REAR
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
    • https://www.supercheapauto.com.au/p/century-century-ultra-hi-performance-4wd-battery-ns70x-mf/602477.html MF for Muthaf*kka
