Brand new built Rb25/30 (Twin cam RB25 head with a RB30 block)
RB25 VCT Head
Head has been fully port and polished (exhaust notches removed as well), crack tested, decked, valve seats cut, cam tunnels ground.
Intake cam 264 10.7mm, Exhaust cam 270 10.2mm (Kelfort Billet's)
Springs have been shimmed to provide extra pressure to suit cams
Nitto head gasket
Spool direct head to sump oil return
Rocker covers have been sand blasted (not painted but prepped)
RB30 Block (With bungs for oil/water lines)
Acid dipped, bored, honed, all new welch plugs, RB25DET oil jets
ACL RB26DETT Forged Pistons
Spool Forged Rods
Crank linished, grub screwed and full length crank collar installed (balanced as a whole with pistons/rods)
RB25DET Oil pump
6 Impellor water pump
ACL Race series big end bearings
ACL Race series main bearings
ARP studs throughout
Ross Metal Jacket Harmonic Balancer
VCT Oil supply tapped into block
Block painted 2 Pac Black
Final compression comes to 8.9:1, the motor is good for around 400-450rwkw
There is more that I have probably forgotten, it also comes with a front facing plenum with an new 80mm throttle body.
I have a fully rebuilt MX7 gearbox to suit if you are interested in that as well.
Machining done by Jack at KC's Engineering in Castle Hill,
Motor build by Mark at MRC in Castle Hill
If you have any further question call me on 0479047910
1. When starting a new thread, you must include a set price, or at the very least a ballpark figure that you are looking for.
Good luck with it.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
