Hello SAU,
I have recently experienced the problem where my tail lights and interior dash lights were not working (Headlights, Brake Lights, small cluster lights e.g. door, ABS etc still works). I have spent the last week researching online for a fix and there were plenty of helpful articles that helped me narrow down what the problem was but it did not fix my problem.
How my problem started:
Wired up aftermarket Head unit and earthed it out what supposely what I thought was the "Earth" wire on the OEM Loom as it was BLACK. You need to earth it out onto the chassis and not into this wire as this is part of the "illumination circuit" , this resulted in blowing the "Tail light" fuse in the fuse box located inside the cabin just above the gas pedal.
Those of you who have already checked the fuses, Please check them on BOTH ends. I had checked the TAIL LIGHT fuse with the volt meter and it showed 12v going to it, but I made the mistake of only checking one end which made me overlook the fact that the fuse was blown.....
For those of you who fuse boxes are in Japanese, here is the link for the English translated version:
The fuse you are looking for is the 10A Tail Light Fuse.
Now there are other reasons the dash and tail light may not be working such as the "Head Light" switch, but if you have recently installed an aftermarket head unit or shorted something out in the car this will be the first thing you should all do before getting into the more complicated things like I did....
I thought I share this with everyone as now I can take the GTR out at night :banana:
I hope this helps.
Cheers,
Tony
https://www.sau.com.au/forums/topic/388798-r32-gtr-no-dash-and-tailights/
Can I make a suggestion - when testing a fuse with a meter, use ohms (resistance) across the blades of the fuse. That way you will always know whether the fuse is intact or blown.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
