  • Replies 177
  • 3 weeks later...
All painted and delivered! :D
Also i have a problem, i went to start the car for the first time for about 10 months, Fuel pumps running, it started, idled for about 5 seconds then died, fuel pump keeps running constanly! im thinking the fuel pump is working just not pumping it to the engine ?? Should i hit around the fuel pump, take it out and clean it or simply replace it ? the tank was dead empty for as i said 10-12 months, i have chucked 25 litres into it but still it keeps pumping and car keeps turning over just no start. any help would be great.
Thanks
Adam
Edited by adambruv
Could be pump, could be sticky injectors. I would buy a 342 Walbro or Deatschwerks and running a relay for it to run 14v. If you need injectors I have plenty here. Sorry to hear mate but these things happen I guess.
GOOD NEWS! Putting 25 litres of fuel into the tank and letting it sit overnight has done some good! car now starts and runs but fuel pump still runs constanly, will grab dads trade plate and take it for a 10 minute drive to see if it stops, if not ill invest in a new one and see if that makes a difference. Took 2 photo for you, its filthy so once i get it out and washed ill take some better ones.
cheers
good news once again!!
I found what the noise was! it was the 4wd pump! that smashed relay i posted on page 3 or 4 is the problem, dad wrigled it around and the 4wd light went off on the dash and the noise stopped :D have to do some more searching to see if i can find a new one, but finnaly everything is nearly finshed on the poor old girl!
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
