  • Replies 177
i now have the grille :P
there's a autech bonnet on there which has the bonnet ornament, hoping he relists it next week once i have money so i can buy it, once i buy that everything i need i have, will just have to wait till it arrives :)
^ that is an ARX with colour coded flares and Axis rims
350S looks just like any Axis from the exterior except that it has the 350S grill that Adam showed above and has the same seats as the PM35 Autech Axis S.
actually it looks like an AXIS with an ARX front bar, check bumper colour difference. height and wheels says it probably started life as an AXIS
I think you're right ; especially considering the Flares are quite glossy, rather than a satin finish like you'd get from painting the coarse ARX Flares.
Probably had a light front ender, and was cheaper to throw an AR-X bar, bonnet & grille on; rather than the AXIS parts.
something is bent in the front left hand wheel area, it sits too far in towards the car, when the wheel is on im lucky to get a finger between the wheel and the car. bought the lower piece(will upload a pic of what i bought), thought it looked a little bent, didnt fix, dad has had a good look, wouldnt have a clue either and he is pretty cluey with cars. once my fan arrives and i have put the front back on ill just have to take it to a crash repairer and let them figure it out
Edited by adambruv
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
