  • Replies 177
Were you familiar with the grill that was on Iain's car?
That is a damn good looking grill IMO and can be found on Yahoo.
yeh forgot about that, but I was always a fan of open grills, and the nismo option was ironically the more expensive option
i have a quick question.
the engine light is on the dash and i have no idea why, who would be the best person tos peak to ? the local auto electricion ? or is there something i can do to find out why its there by myself ?
cheers
1. Ignition to "ON", wait 3 secs
2. Depress/Release pedal 5 times within 5 secs
3. Wait 7 secs and press accelerator pedal to the floor
4. Wait until CEL flashes then release pedal.
5. Count flashes to retrieve the CEL codes (10 flashes is a zero value and codes are in groups of 4 values)
Sounds like a sensor has gone over 5 volts at some stage- just reset and see if it comes back before trying to find out what sensor
google copy paste
OBD Code P0651refers to
These 5-volt reference circuits are independent of each other outside the PCM, but are bussed together inside the Engine Control Module (ECM). Therefore a circuit condition on one sensor 5-volt reference circuit may affect the other sensor 5-volt reference circuits. The ECM monitors the voltage on the 5-volt reference circuit.
Causes
Possible causes of OBD code P0651
- Shorted sensor - Shorted sensor circuit - Failed ECM The Error code is generally activated on detection of the following conditions: The ECM has detected an out of voltage range on the 5 volt reference circuit 2
  • 1 year later...
Threads shouldn't be deleted just because you're trying to sell the car without mentioning its a RWO in the sale description.
Lol, nicely played Dunc.
Honesty is the best policy.
Ask Edward Lee. :whistling:
Perhaps sale thread should be linked to this thread to demonstrate the hard work required to achieve a successful repair?
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
