Hi peoples,
Just wondering if anyone has had their front control arm bushes (inner and out) replaced recently and roughly how long the job was?
I am looking at getting the Nolathan bushes and found some good suppliers on ebay, however just wondering what amount of labor time was involved to get these replaced.
Would it be a big job or something I can take down to my mates a Kmart Tyre and auto to do over a few hours?
Sorry if I am coming across a bit ignorant and a nube!
https://www.sau.com.au/forums/topic/388817-recommendation/
on the hoist here at work i can get each side done in about 30 mins to 45mins so arm out old bushes out new bushes in arm back in the car and wheel aligned in about an hour and a half with no problems ie stripped nuts and bolts etc. fairly straight forward job.
https://www.sau.com.au/forums/topic/388817-recommendation/#findComment-6206047
So it should not take no more than 2-3 hours max? A couple of places I went to advised me they wanted the car for the whole day as the process of getting the Nolathane bushes "pressed" was not that straight forward.
These are the ones I want to get installed - just wondering if they do require extra time for installation.
http://www.nolathane.com.au/product_detail.php?part_number=45485
Control arm - upper outer bushing
http://www.nolathane.com.au/product_detail.php?part_number=45465
Control arm - lower bushing
https://www.sau.com.au/forums/topic/388817-recommendation/#findComment-6208990
I was under the impression you were just talking about the traction (castor) bush for some reason...Not sure why.
Anyway, those two are not the most time consuming on the car. But are fiddly.
doing the lower inner is where the difficulty is. Pressing that one may take some time. As you will probably need to take the lower arm off the hub etc.
The upper outer will take 45-1 hour'ish each side.
The lower inner, not sure depends on how easy the thing come out of there.
But 1/2 - 2/3 of the day sounds ok to me.
https://www.sau.com.au/forums/topic/388817-recommendation/#findComment-6209006
Thanks.
That makes sense now.
Kmart Tyre and Auto advised me with two mechanics working on the car at the same time they can do it in 2/3 hours.
I think I should just budget for half a day to a day to make thing easier for myself.
https://www.sau.com.au/forums/topic/388817-recommendation/#findComment-6209028
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
