Hey guys,
Anyone got some tips or ideas for mounting the 044 as an intank pump?
Searched the forum and only for one article about it where a guy used an EB falcon fuel sock attached to it
I can't find a fuel sock anywhere no shops stock them or anything. Ideas would be great
Thanks
https://www.sau.com.au/forums/topic/388849-bosch-044/
No because you shouldn't do it.
an 044 pump is a feed pump ONLY it will not draw fuel like a walbro or any of them correct intake pump, unless it is gravity feed these pumps will fail.
This is why there is no information for you to search.
Dont listen to this guy^^^
Car is a R33 right? I just modified the cradle and used some clamps to fit the pump and also fitted a new clean sock (old one was brown).
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197061
I purchased the fitting kit for an 044 through JEM - ingleburn.... Its just a sock that goes on the base of the 044..... They look like a bitch to fit though due to the size of the pump!!!
I read the DIY on installing fuel pumps on this site this morning after swapping pumps with a mate last night, was a PITA :glare:
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197112
Is it worth the hassel?
Someone just pmed me saying the following:
These pumps are a pain to fit up.
They need the factory bracket cut off and then the pump is clamped to the bracket.
Factory steel fuel pipe has to be removed from the bracket too.
The height on the bracket is critical or the pump won't suck all the fuel, car will conk out on 1/4 tank.
You have to do this just right too or the clamps will foul inside the tank, even then the pump body is a bit too large to fit easily and heaps of force is needed to get it on and off the bracket's slot again.
I modified a hose barb (removed the barbs) and then the stock sock pushed over nice and tight.
Wiring needs to be altered as the terminals are much larger than factory. Make sure you don't get positive and negative back to front.
The pump is supposed to have a non-return valve on the outlet. Usually this costs another $30.
If you run it without the valve (as I did in the photos) the fuel drains back to the tank overnight and you have to do a few key on-offs to prime the rail in order to start the engine. Gets annoying so I pulled the pump, bought and fitted the valve.
This then needed a touch up of the tune, car had some lean spots as the valve is very restrictive.
The 044 is very, very noisy, usually because it's touching some part of the tank inside.
This is so hard to get correct as it's a bastard of a job to remove and re-try
I'll never buy another 044 but back then the other options weren't so readily available as they are today.
Tomei etc make a drop in pump, no hassles.
Regards.
Edited by Kasko
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197172
the noise issue can helped a lot by getting some fuel resistant PVC tube from clark rubber and using metal worm drive clamps to hold the pump to the stock bracket with the PVC between.
i used to have pictures of my pump attached to the bracket but i am unsure where i put them.
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197196
The 34GTR pump was noisy in my car as it was hard mounted, however i found the Walbro we pulled out of my mates car has a jacket on it and it was apparently still loud anyway? :huh:
Here is a pic of the bracket with the end cut off and the clamps, its nowhere near the size of the Bosch units etc but its more so for the posts above -
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197207
Titan mate that looks perfect!
When I do mine im going to make a tutorial on how to do it.
Where did you get the fuel sock from? I searched everywhere in fyshwick yesterday and no one sells them
its the stock one off the stock pump.
fittings were from pirtek, pvc tube from clark rubber.
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197240
I might just kick back and wait for this tutorial :D
So Titan, comparing to other fuel pumps, the noise is OK?
https://www.sau.com.au/forums/topic/388849-bosch-044/#findComment-6197248
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
