flame_this Posted January 20, 2012 Share Posted January 20, 2012 Pulled this off another forum for reference with the boost control kit. my question is in post 2 The R33 RB25 is L-jetro. Below is a bunch of information about boost controller kit for the Power FC. I do not know if the GReddy MAP or Valve will work. I purchased a used APEXi AVC-R controller and a new APEXi boost controller kit harness and installed it as the boost controller add on kit for my Power FC. This is the closest you will be able to get to the D-jetro MAP sensor system as you can get without going full stand alone like AEM or whatever have you. I also highly recommend purchasing a FC datalogit box so that you can connect a laptop up and get full program ability out of the Power FC unit. The FC Datalogit box is far superior to the FC Commander(hand controller). APEXi 415-A001 Boost Controller Kit: For those of us with the APEXi Power FC the 415-A001 kit is the add on kit we can get to control our boost level. Resized to 20% (was 500 x 375) - Click image to enlarge " POWER FC - FAQ by Paulr33 @ SAU I was searching for the APEXi part numbers when I ran across this FAQ on Google. Map Sensor: 499-X001 Valve: 499-X003 Harness: 49C-A002 Exerpts from Paulr33's website The optional boost controller kit for the Power FC consists of the pressor sensor, pressure sensor harness and solenoid. The solenoid should be plumbed between your manifold and the wastegate actuator (internal wastegate setup). For external wastegate setup it should be plumbed between the manifold and your external wastegate pressure line. The pressure sensor should be plumbed in parrallel with the factory MAP sensor which is used by your standar boost guage. The solenoid has two labels on it, you should match them accordingly COM line should goto wastegate actuator NO line should goto intercooler piping It can be T'eed into the plumbing with its included T piece fitting. Boost Controller Kit Type #1 3 wire plug, Solenoid runs to stock boost control loom on stock ECU wiring loom. 3 wires in Apexi loom are for Map sensor - Signal, Ground and Power Boost Controller Kit Type #2 5 wire plug, Solenoid runs to map sensor harness which runs to Boost Controller port on PowerFC 3 wires are for Map sensor - Signal, Ground and Power. 2 Wires are for Solenoid Power and Ground Skyline RB25DET PowerFC and GTR RB26 Uses Type #1 The pressure sensor has the main wiring harness directly attached to itself, one end plugs into the 5 pin port on the PowerFC. The solenoid piggybacks off the Pressure Sensor wiring harness which leads to the PowerFC connector port. The wiring is shown below. MAP Sensor Red = Positive Black = Negative (earth) Green = Signal Solenoid Pink = Positive Black = Negative When the solenoid wiring meets with the Map Sensor harness the colours for the Soneoid change as follows; Pink = Red Black = Brown Boost Control Kit - Parts Inventory Resized to 9% (was 1226 x 879) - Click image to enlarge Boost Control Kit - Complete Kit Resized to 13% (was 800 x 588) - Click image to enlarge Boost Control Kit - MAP Sensor Resized to 13% (was 800 x 398) - Click image to enlarge Boost Control Kit - Solenoid Resized to 13% (was 800 x 698) - Click image to enlarge Apexi PowerFC - Plug Layout Resized to 55% (was 184 x 71) - Click image to enlarge "Boost display without the Boost Control Kit? By default as the PowerFC will not show boost pressure as it has no method of reading it in via the stock ECU loom. If you purchase a suitable map sensor and connect it to the PowerFC boost control kit port then the hand controller will display boost pressure. The boost control kit uses a Denso map sensor which is part #DPS 310 2000a - Denso 949940 6270 5V and the wiring loom cable/plug can be brought from Apexi which is around $40 AU. The cable is listed as the 3pin boost control harness. Nengun has this listed under Electronics -> Apexi -> D Jetro Option Parts Alternatively below is the pin out diagram for the Boost Control Kit port. This is for the 3 pin version only. I am unsure of the pinouts for the 5 pin version. Resized to 32% (was 320 x 240) - Click image to enlarge 1 = Voltage+ 2 = Signal 3 = Ground " I have done this on my car and it works correctly. I used the boost control kit harness ($30 new) and the Boost Control kit Map sensor and stepper motor. I connected them up using the supplied plugs & loom and plug it into the PowerFC Boost Control kit port. I purchased the Wire harness 3 pin for ~$25 dropped shipped from APEX integration. The plug on the valve will not just plug into the R33 S2 plug on my car for the stock solenoid. You will have to cut your AVC type R controller harness and solder the APEXi valve plug to your engine harness so it will work. I have supplied the wire colors needed to do this and a multimeter will quickly tell you which wire is the + wire for the stock valve and the ECU controls ground. I also rerouted the valve vent which you will be instructed to vent to atmosphere to vent into the BOV return tube as Nissan had done from the factory. As far as the timing advance goes I have not touched the stock ignition or fuel maps in the PFC. I can get it to knock at high rpms(5K+) under full throttle under heavy load. I would venture to say if your fuel system is setup correctly that light driving under stock conditions would be okay. I have noticed that the stock map settings are on the rich side of things, probably as a safety precaution. I've seen it go to low 11AFRs under heavy foot operation with both my wide and narrow band. Hopefully this will help you. 0 Link to comment https://www.sau.com.au/forums/topic/388854-using-avcr-to-display-map-on-power-fc/ Share on other sites More sharing options...
flame_this Posted January 20, 2012 Author Share Posted January 20, 2012 can i simply wire the MAP signal wire from the AVCR MAP sensor to the correct pin on the 3 pin power fc i have so i can display and log the boost correctly on fc edit? cheers Link to comment https://www.sau.com.au/forums/topic/388854-using-avcr-to-display-map-on-power-fc/#findComment-6196868 Share on other sites More sharing options...
BarbsGTR Posted June 26, 2013 Share Posted June 26, 2013 (edited) can i simply wire the MAP signal wire from the AVCR MAP sensor to the correct pin on the 3 pin power fc i have so i can display and log the boost correctly on fc edit? cheers I was thinking something similar. Taking the signal boost wire from my bnr34 mfd to the green signal 3 pin power FC port.All I want to be able to do is log boost in FCC datalogit. Hopefully Paul can review the idea Edited June 26, 2013 by BarbsGTR Link to comment https://www.sau.com.au/forums/topic/388854-using-avcr-to-display-map-on-power-fc/#findComment-6906050 Share on other sites More sharing options...
