Hey guys,
I've read a lot about people having problems with their clutch grabbing too low. My problem is the opposite where the friction point is way too high (pretty much 1cm from the top).
I've tried readjusting the pedal but it doesn't seem to do much - bite point stays the same, pedal just get sits lower or higher depending on how its adjusted. Can this be fixed or is it just a case of a worn clutch?
Its a '94 r32 GT-R
Thanks
https://www.sau.com.au/forums/topic/388864-clutch-help/
Yeah that's the one. Right now the U bracket that's connected to the back of the pedal is all the way at the end of the push rod.
Adjusting it all the way down the other way makes a little difference to the height at which the pedal sits naturally but no difference to the grab point of the clutch.
https://www.sau.com.au/forums/topic/388864-clutch-help/#findComment-6197086
if you have a 94 gtr you have a pull type clutch like in my r34. they tend to have a higher engagement point than the traditional pull type. how many km are on the car? do you know if its the standard clutch? if it turns out to be worn as well then this will make the engagement point higher. hope this helps :)
https://www.sau.com.au/forums/topic/388864-clutch-help/#findComment-6197680
Dunno if its standard but I know its a twin plate from the noise it makes. Bout 120 xxx kms on it (probably been wound back). Thanls for your input, ahhbee. Kinda confirms a worn clutch.
Do you know if bleeding + replacing clutch fluid could help?
https://www.sau.com.au/forums/topic/388864-clutch-help/#findComment-6197992
unless the pedal feels really soft and spongy bleeding the lines probably wont make a difference, with the km it has and the fact that very few skylines have been babied there whole life i also think its probably a worn clutch. im kinda in the same boat actually, my clutch is worn and as such the engagment point is about 10/15mm from the end, instead of about 25mm where it would be with a good clutch. its still perfectly drivable, just have to be a little more carefull and not slip it away from lights etc.
ps. in my last post i meant to say pull type will be higher than the traditional push type
https://www.sau.com.au/forums/topic/388864-clutch-help/#findComment-6198316
Pedals are pretty firm actually. Guess i'll try and milk this clutch til it starts to slip a bit more before I go shopping for a new one.
Got a pretty stock gtr so wouldnt be surprised if it lasts ages.
Thanks again!
https://www.sau.com.au/forums/topic/388864-clutch-help/#findComment-6198608
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
