  • Replies 87
I asked a simular question when i 1st came on this site about the cheaper turbos and soon got drilled about it. Obviously by putting one of these turbos on he would be running his engine at risk. However ive also watched a lot of vids of youtube with the yanks and there ebay turbo engine builds (mainly on honda civics). some last a year or so and some dont. Mafia also said to me that most of these turbo only last one or to runs on the dyno then they blow oil seals.
If ur mate does decide to go ahead with this turbo then atleast msg other ebay users who have bought it and ask them what its like, preferably the buyers who bought it a while ago so they can tell u if the turbo is still running ok or shat itself
There's nothing wrong with trying a cheap turbo, but putting one on while you wait a week or two for your genuine Garrett to arrive is simply retarded.
It's one of the silliest things I've read on here thus far. And I read most of NewB's inane bullshit!
how is it $700 on a temp turbo ive told him not to do it but he is and will be putting it on the dyno
It's going to cost a solid $50 to post, he'll likely need different oil/water lines and a dump pipe. Then there's fitting and/or tuning.
$700 is likely a conservative estimate.
OMG im not a newb and its a direct bolt on for all the lines and dump pipe even the factory cooler piping fits and its $426 delivered
his turbo is 2 weeks away then a further 2 weeks for the exgate and to modify the stock manifold then a week for the dump pipe so after he sells the stock turbo for 250 or so its only 150 more to try a turbo for a few weeks
yeah ill tell him pretty sure his gonna do it
at the end of the day theres plenty of people using ebay turbos
ie kando and i remember when taos turbos first came out they were only sold on ebay and i remember 5-6 years ago people were worried about them and saying the same stuff but now look most people swear by them
Kando, made in Japan using Mitsubishi components. Hyper gear, made in Australia alot of testing. China turbos, made from cheap, inferior components, not tried, hardly tested and not proven. People aren't giving you or your mate shit about turbo choice, no, it's the whole idea which is horrible and an utter waste. a proper turbos compressor wheel cost as much as that Chinese turbo cost to cut out of raw material. You want to tell me they are reliable? Imagine what the core looks like.
I recon if your mate did do this, he will have the Garrett in his hands before this China turbo is running and tuned on his car.
And it's not a direct bolt on, you are going to need a new hot pipe or silicone bend.
Edited by SargeRX8
My opinion in 3 points:
- I would probably try that turbo for the lulz factor of it possibly being very good (it seems to be a completely custom turbo).
- I would NOT buy another turbo for ANY reason if I already had one on order.
- YOU MUST GET IT TUNED.
K I'm done.
lol ill ban them all :P nah its just a forum joke, some forums even have a smiley that holds a sign saying 'pics or ban'
like when someone says 'just fitted my te37s' you say 'pics or ban'
you said '280kw $400 turbo just got off the dyno' i said 'pics or ban'
yeah all good hahaha but yeah i went in his car and omg it was impressive for a $400 turbo he has been giving it a really hard time and no signs of wear of shaft play YET but we will wait and see
come on guys lets see some more people try this if i was goin to get a gt3071 again or a highflow i would snap this up
EVERYTHING bolted up once he removed his stock turbo 100% no problem at all just needed a new silicone bend but thats it
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
