  • Replies 87
I asked a simular question when i 1st came on this site about the cheaper turbos and soon got drilled about it. Obviously by putting one of these turbos on he would be running his engine at risk. However ive also watched a lot of vids of youtube with the yanks and there ebay turbo engine builds (mainly on honda civics). some last a year or so and some dont. Mafia also said to me that most of these turbo only last one or to runs on the dyno then they blow oil seals.
If ur mate does decide to go ahead with this turbo then atleast msg other ebay users who have bought it and ask them what its like, preferably the buyers who bought it a while ago so they can tell u if the turbo is still running ok or shat itself
There's nothing wrong with trying a cheap turbo, but putting one on while you wait a week or two for your genuine Garrett to arrive is simply retarded.
It's one of the silliest things I've read on here thus far. And I read most of NewB's inane bullshit!
how is it $700 on a temp turbo ive told him not to do it but he is and will be putting it on the dyno
It's going to cost a solid $50 to post, he'll likely need different oil/water lines and a dump pipe. Then there's fitting and/or tuning.
$700 is likely a conservative estimate.
OMG im not a newb and its a direct bolt on for all the lines and dump pipe even the factory cooler piping fits and its $426 delivered
his turbo is 2 weeks away then a further 2 weeks for the exgate and to modify the stock manifold then a week for the dump pipe so after he sells the stock turbo for 250 or so its only 150 more to try a turbo for a few weeks
yeah ill tell him pretty sure his gonna do it
at the end of the day theres plenty of people using ebay turbos
ie kando and i remember when taos turbos first came out they were only sold on ebay and i remember 5-6 years ago people were worried about them and saying the same stuff but now look most people swear by them
Kando, made in Japan using Mitsubishi components. Hyper gear, made in Australia alot of testing. China turbos, made from cheap, inferior components, not tried, hardly tested and not proven. People aren't giving you or your mate shit about turbo choice, no, it's the whole idea which is horrible and an utter waste. a proper turbos compressor wheel cost as much as that Chinese turbo cost to cut out of raw material. You want to tell me they are reliable? Imagine what the core looks like.
I recon if your mate did do this, he will have the Garrett in his hands before this China turbo is running and tuned on his car.
And it's not a direct bolt on, you are going to need a new hot pipe or silicone bend.
Edited by SargeRX8
My opinion in 3 points:
- I would probably try that turbo for the lulz factor of it possibly being very good (it seems to be a completely custom turbo).
- I would NOT buy another turbo for ANY reason if I already had one on order.
- YOU MUST GET IT TUNED.
K I'm done.
lol ill ban them all :P nah its just a forum joke, some forums even have a smiley that holds a sign saying 'pics or ban'
like when someone says 'just fitted my te37s' you say 'pics or ban'
you said '280kw $400 turbo just got off the dyno' i said 'pics or ban'
yeah all good hahaha but yeah i went in his car and omg it was impressive for a $400 turbo he has been giving it a really hard time and no signs of wear of shaft play YET but we will wait and see
come on guys lets see some more people try this if i was goin to get a gt3071 again or a highflow i would snap this up
EVERYTHING bolted up once he removed his stock turbo 100% no problem at all just needed a new silicone bend but thats it
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
