i think people are confussed it had a full tune for all the bolt ons but for a gt3071 then all he did was change the turbo nothing else still somewhat a full tune
its not like he took his stock turbo off ran a gt42 and turned the boost up
  • Replies 87
I need to link the facepalms again....
Edited by Cowboy1600
hahahahahahahahahahahahahaha
I want to see a boost graph, my guess is it's got a whole guts full at 140km/hr
The power to rpm ratio is wores then my 3540 mokup (hypergear atr45) while 160kws short. Looks very lazy and not making much power either. Not a very good turbo.
well there must be something wrong with the tuner/turbo or engine cause it was very close power very close dyno to not much difference at all across the whole board
lets just think its a $400 turbo hg are 1500 so its not a bad power figure for the price
Have you seen a dyno graph for a 3071? That dyno graph up there is disgusting. Sags and flops and makes power at what about 5krpm then falls off all the way to red line. I bet that housing on the turbo will glow red after a couple runs.
If I had to do it all over again, knowing what I know now, I would still go hypergear over this turbo. Keep it for a Civic, a skyline deserves more.
Edited by SargeRX8
yeah i kno but its not mine and not in a skyline his goin to a gt3076 just wanted to do this at a laugh
and i know his dyno graph of the gt3071 i was there and watched it
not goin to name names but the tuner is known for bad tunes he has done a fair few shitty tunes here in melbourne
sayin that he might goto a different tuner and try another power run of a new fresh tune
his 3071 was pretty much the same as the dyno i put up there not much difference at all so giving the 3071 dyno sheets are better then this then it clearly rules out the turbo
so its either engine/ or tuner
i know you want this to be the most awesome turbo in history, but face facts... it isn't.
at this point you cant really say anything about the tune/tuner as it doesn't have one.
yes you DO need to tune for the different turbo, even if it makes similar power. also the kw figure is probably the least important part of the tune, and not the reason we tune cars. it's not how many kw you make, but how you make them
this is what a ~280rwkw turbo on an RB 25 SHOULD look like:
note the response.
yeah i know what your saying joey , i kno its not the best turbo but what im trying to say with the tuner who tuned his engine using a gt3071 the dyno graph looked excatly the same as the one i posted which seems to tell me its the tuner as it didnt look very good even with the garrett turbo with a full tune
i dont want to name the guy who tuned it but i kno alot of people have had problems with him maybe i should tell my mate to go visit trent and get a REAL tune done
i guess thats there opinion as i dont really have one as its not mine i couldnt care less only stating that its still goin strong for a shitty $400 bolt on turbo with no tune
its booked in for a tune next week so i guess we will see what its like
1328700312[/url]' post='6224982']
Kudos to him for at least giving it a go, after all it's not that often you see proper results of a eBay turbo posted up. It may not be as good as a legit garret, but at least it's making some sort of boost...then technically it's doing what it's meant to do...in saying that though I would have waited for the proper one...and he can't sell it and make any means of profit off it...it's already a cheap turbo, a used eBay one you'd probably have to pay someone to take it away haha...
Nice job anyway. Like others have said a photo of the turbo on the car would be nice...Cheers!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
