ITS NOT MINE ITS MY FRIENDS just wanted to see if anyone has had experience with this turbo as not many ebay ones have been a true bolt on
and once the turbo is fitted it will go back to the tuner to make sure everything is ok
Sounds like you've already made up your mind.
It is a dumb idea, we all think it is a dumb idea, but because this is what you want to hear I am going to say it.
SWEET IDEA DUDE, f**k YEAH BOOST IT WITHOUT A TUNE WHO CARES IT'LL BE SICK!!!
edit: lol you actually did it, kudos for posting up that horrible dyno graph, looks like you took a picture of some waves at the beach haha
Edited by Rolls
  • Replies 87
hahahah i dont really care as ive said so many times yet no one really reads ITS NOT MY CAR NOT MY TURBO I DONT CARE WHAT HAPPENS TO IT JUST REPORTING A FRIENDS OUTCOME WUTH A BOLT ON EBAY TURBO AS NO ONE ELSE DID IT AND HE THOUGHT ITS WORTH A LAUGH
FOR A UNTUNE ECU I THINKITS ACTUALLY NOT TO BAD WITH THOSE NUMBERS I CAN WAIT TO SEE WHAT ITS LIKE WITH A TUNE BUT SAYING THAT THE ECU WAS SOMEWHAT TUNED BY A TUNER ON HERE WHO WILL REMAIN NAMELESS TUNED IT ALL WITH A GARRETT GT3071 SO ITS REALLY NOT A BAD OUTCOME IVE SEEN WORSE
I GUESS TIME WILL TELL AND A PROPER TUNE WILL ALSO TELL
  • 9 months later...
hey guys...i hv been using this one for a couple of months now
http://www.ebay.com.au/itm/251078425474?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2697wt_1271
i have gone to a workshop when my engine was totally stock and the mechanic said that it was ok to use this turbo and will get about 300hp.. .so far i have not been able to 300hp. He told me to get a few after market stuff etc in order to achieve the 300hp...he ran the engine on the dyno more then 5 times but still didnt get the results..and still i didnt know the hp at that time. I was thinking he has not much experience on performance modifications...
Then i got some feedback from SAU members who told me to take my car to another workshop to solve my problems. The mechanic there ran my engine on the dyno more than 20x and now i get the actual readings on the safe tuning which is 196kW. Until now, the turbo has not given me any problem and i would like to try to get 250kW with ECU, injectors and AFM. I hope i will be able to get this running on the same bolt on turbo. I dont mind if this turbo burst (since its a cheapo anyway) as long as my engine is intact. i m shocked that yur friend got 260kW on the cheap turbo... :w00t: btw the mechanic did not advise to use these cheapies if you want to keep yr engine safe and running for a long time.
I know some members here told me to get a good turbo but atm this is the only one i can afford as i m working pt and studying...i am surviving on instant noodles to save n get one of those good brand turbo plus labour to fix it to my car LOL...
Guys..pls dont grill me on my opinion since i m a newbie in the engine modification environment.... :worship:
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
