  • Replies 87
HE checked it all its pretty easy to check as he has the afm in the cooler piping
so he is checking it to make sure its all good
looks pretty perfect cant complain for the price as it didnt cost extra to bolt on and made the same power less 3-4kw of his gt3071
i ran a poorly built monsta t3 about 5 years ago lasted 3 and a half yeaers on 17psi before i sold the car and upgraded ive seen alot of people run turbos off ebay there seems to be more people having problems with cheap inlet manifold and highmounts over turbos
but this turbo doesnt look like many people on here have tried it YET :)
It sounds too good.
He bought an eBay turbo, with a tune for a completely different turbo, bolted up perfectly and ran it, WITHOUT TUNING IT, and made 260rwkw. That is more power than I am making at the moment with a bigger turbo, more boost and a full tune.
he has been giving it a really hard time and no signs of wear of shaft play YET but we will wait and see
lol @ checking for wear and shaft play after less than 24 hours of it being installed... :rofl2:
MOST AWESOME POST EVER ON SAU. Nearly pissed myself laughing
Yet he's considering spending what will likely end up being ~$700 on a temp turbo?
WTF?
Cutting spending on education clearly isn't working. Then again, someone has to fit my tyres....
It sounds too good.
For the moment, have to call bulls***, as much as i'm for a good cheap deal, this one seems too cheap and too good, and the graph looks like it was done with excel....
If he's actually done it, f*** yeah and well done. full tune and more boost should make ~300rwkw? Good work.
hahaha excel i dont even know how to use word lol
its all legit nothing has been done to alter the reading its a real dyno read from his car with this $400 bolt on turbo
i guess everyone can say what they like at the end of the day its not my car
he wanted to test it and its proven to be really good
y dont others off here try the same if you doubt it
after all its only $400 and could always sell the turbo to the guys on calaisturbo or r31 club
i wonder who else s face palming them selves arfet a 400 turbo tuned for a different turbo makes decent power
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
