ITS NOT MINE ITS MY FRIENDS just wanted to see if anyone has had experience with this turbo as not many ebay ones have been a true bolt on
and once the turbo is fitted it will go back to the tuner to make sure everything is ok
Sounds like you've already made up your mind.
It is a dumb idea, we all think it is a dumb idea, but because this is what you want to hear I am going to say it.
SWEET IDEA DUDE, f**k YEAH BOOST IT WITHOUT A TUNE WHO CARES IT'LL BE SICK!!!
edit: lol you actually did it, kudos for posting up that horrible dyno graph, looks like you took a picture of some waves at the beach haha
Edited by Rolls
  • Replies 87
hahahah i dont really care as ive said so many times yet no one really reads ITS NOT MY CAR NOT MY TURBO I DONT CARE WHAT HAPPENS TO IT JUST REPORTING A FRIENDS OUTCOME WUTH A BOLT ON EBAY TURBO AS NO ONE ELSE DID IT AND HE THOUGHT ITS WORTH A LAUGH
FOR A UNTUNE ECU I THINKITS ACTUALLY NOT TO BAD WITH THOSE NUMBERS I CAN WAIT TO SEE WHAT ITS LIKE WITH A TUNE BUT SAYING THAT THE ECU WAS SOMEWHAT TUNED BY A TUNER ON HERE WHO WILL REMAIN NAMELESS TUNED IT ALL WITH A GARRETT GT3071 SO ITS REALLY NOT A BAD OUTCOME IVE SEEN WORSE
I GUESS TIME WILL TELL AND A PROPER TUNE WILL ALSO TELL
  • 9 months later...
hey guys...i hv been using this one for a couple of months now
http://www.ebay.com.au/itm/251078425474?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2697wt_1271
i have gone to a workshop when my engine was totally stock and the mechanic said that it was ok to use this turbo and will get about 300hp.. .so far i have not been able to 300hp. He told me to get a few after market stuff etc in order to achieve the 300hp...he ran the engine on the dyno more then 5 times but still didnt get the results..and still i didnt know the hp at that time. I was thinking he has not much experience on performance modifications...
Then i got some feedback from SAU members who told me to take my car to another workshop to solve my problems. The mechanic there ran my engine on the dyno more than 20x and now i get the actual readings on the safe tuning which is 196kW. Until now, the turbo has not given me any problem and i would like to try to get 250kW with ECU, injectors and AFM. I hope i will be able to get this running on the same bolt on turbo. I dont mind if this turbo burst (since its a cheapo anyway) as long as my engine is intact. i m shocked that yur friend got 260kW on the cheap turbo... :w00t: btw the mechanic did not advise to use these cheapies if you want to keep yr engine safe and running for a long time.
I know some members here told me to get a good turbo but atm this is the only one i can afford as i m working pt and studying...i am surviving on instant noodles to save n get one of those good brand turbo plus labour to fix it to my car LOL...
Guys..pls dont grill me on my opinion since i m a newbie in the engine modification environment.... :worship:
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
