  • Replies 40
More than happy to take you for a run but if you're going to run -5's on a standard sized engine the impression might not be a true indication due to the stroker.
Definitely not a good indicator, i can tell you that! :D
i bought those hks step 2 valve springs and stupidly did not pressure test them......car felt a little fluffy but kept on trucking for about a year then took the head off,removed the valves and it looked like they had been floating....put them on a pressure tester and they were shite!!!!!!got some random ones from austral and whammo.....all good
OK, Little progression update
R34 dumps and Nismo Front pipes
Splitfire coil packs
ID 1000's
R32 GTR front seats
Will i be able to use my current airbox? Will just be going with a hi flow panel.
Next on the list
BC BR coilovers
Get 350z rims to get Powdercoated ( black)
Then money aside for some quality rubber
Also, cant find what thread, Though someone commented on my water pump or oil pump and said it was no good? if so this is something i would like to sort asap.
another thing thats just poped to mind is Radiator, Not really keen on leaving the stock one it has at the moment, Probably more of a piece of mind thing but will be going in as the Front mount gets set up.
Probly just go with a GTR stock FM, Unless unigroup advise otherwise.
Not everyone can afford to buy a GTR then run it... so never goin to happen lol :nyaanyaa:
If he hasnt told you abuot it then he deosnt think u need it
Replaces the CAS for a more accurate engine timing signal
is your car there now?
a "Y' pipe is a pipe that fits onto the front of a turbo.. generally a big single, it flares into a 'Y" so you can adapt 2 filters/AFMs onto it for the intake.. also has a seperate pipe on the underside to plumb back a BOV if desired
I have a Greedy one if you wanna buy one
Edited by GTR_JOEY
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
