Hey All
Want to get rid of my old car. Its engine may appeal to someone hence why I have advertised it here. Although it is fun to surprise people...
Its has been mod plated for RB30/25 engine conversion.
6BOOST manifold with GT35/40 turbo both done less then 2000kms. Just bought a turbo beanie. Turbosmart 50mm Progate external wastegate.
Greddy style (copy) forward facing plenum with 900cc injectors. Semi hidden front mount with 2 1/2" piping.
Haltech E6X ECU
Eboost 1 controller in glove box.
Turbosmart Veeport BOV.
Undercar surge tank with two bosch fuel pumps. I believe they're the 910 ones.
Keas internals Jatco 3 speed. Full manualised. B&M Proratchet shifter. 5500 stall converter. And transbrake. Transcooler.
3.9 diff gears with detroit locker.
3" mandrel exhaust, with twin 2 1/2" tips. Battery relocated to boot with an isolator switch.
massive radiator and electric water pump. Has a 16" thermo fan with a manual override switch.
Fire extinguisher inside.
Windows are tinted nice and dark.
Mongoose M80S central locking and alarm system. This works in sync with the turbo timer.
Seats are standard but have been retrimmed in XR6 pattern cloth.
Wheels are 18" Advanti Volts bout 50% tread.
On street tune of 17psi it made 357 rwhp. Car is very fast but it needs more traction. .
I have spent a lot of money getting the car to almost where I wanted it.
But decided to upgrade to a Monaro.
Car will be sold as is. With no rego. Car is located in Toowoomba (Westbrook).
It isnt registered so if you want to look you will have to go out to my olds place which is down a gravel road. Im not there during the week but can come out on weekends.
$10 000 offers over $8000 considered.
Cheers Dave 0437 463 007
https://www.sau.com.au/forums/topic/388890-vn-running-an-rb3025-and-powerglide/
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
