(Sa) R32 Nissan Skyline
Contact:O4O2 9O2 759 (Matt)
Car: 1993 Nissan Skyline R32
Tein Type NA Coilovers
Exedy Sportstuff clutch
17"x9" P1 Buddyclub Wheels with 99% tyres
Boost Controller
Nismo shift knob
Momo Steering wheel
3" Exhaust (cat-back)
GTR front bar and rio
GTR fuel pump
GTR Vspec II boot lid
Genuine N1 lip
Genuine R32 GTR Rear Wing
FMIC
New Castor Rod Bushes
New Front Upper Control Arm Bushes
Everything else is factory including factory electric sunroof, folding mirrors and digital climate control all still works
Ive had this car for around 2 years, as with any car of its age it has a few marks on the body but its in reasonable condition. Engine, Gearbox, Brakes and Diff are all in very good condition with no mechanical faults. Any inspection welcome,
$8,900 ONO or will swap for a cheaper car + cash, Willing to remove wheels or other parts to reduce price.
Edited by JiN_MaN
  • 4 weeks later...
  • 4 months later...
  • 1 month later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
