so that pictured unit only picks up SD tv and not HD channels?
is there something that denotes that on the zylux website?
Yes unfortunately. But im not too fussed about it. Its still a digital tuner, just not HD.
When I ordered it, i was lead to believe that they only sell the new HD model now. So i didnt go out of my way to specify. Of course the old model turned up! Make sure you specify you want the new HD version.
I dont think the new model appears on the website yet. Here is the link for the one I got. Zylux tells me the only thing different about them is that the new one has the HD channels.
The rrp is around $500. JB cost price is $349. Offer them somewhere between $375 and $400 and you should get it.
http://www.zylux.com.au/aus/digital-tv-receiver-with-recorder.html
That tuner looks pretty cool, the fact that its in English makes a difference. I will check again for this tuner.
Do you know whether our cars will play certain video files from CF card?
Not sure, Im still waiting for my CF card to arrive in the mail.. The tuner definatley plays all relevant formats though.
  • 1 month later...
I ended up getting JB to reorder the correct HD tuner for me. I was hoping it would be a direct replacement wiring wise. Of course it wasnt. The plugs and wiring were different. Also the they changed I/R sensor plug meaning i had to pull apart the whole interior again to install it :down:..
Anyway the interface is a little different looking but still good. The reception and AV quality is awesome. The physical size of the unit is a little bit larger, i had to change the bracket location. The new one has HDMI output. One little complaint is that the old tuner used to power up as soon as you start the car, this one doesnt. As well as that, it takes a bit to get it going, you need to press the power button on the remote a few times before it comes on and stays on. I called Zylux and apparently thats just how this new model is.. I really want to get to the bottom of this so sort of still a work in progress. I did notice when i swapped over from the old model that they used a thinner gauge of wires for the power and grounds on the new one.. I wonder if that might have something to do with it...?
Anyway heres a few pics installed.
  • 1 year later...
Hey guys, I have a question. I notice my car has the same panasonic digital tuner and from the tuner, there are 3 av plug-ins (usual red, yellow and white) which says AV in. However, I noticed that I don't have the 3 AV inputs in the center glove box although there are 3 holes underneath the japanese phone jack. Any idea if this is common and can I use the AV in from the tuner to run something to the car's monitor? Thanks!
  • 1 month later...
Loving google chromes built in translate feature... Found the actual Jap install instructions.
http://minkara.carview.co.jp/en/userid/859533/car/722285/1337084/note.aspx
Found the install that the Jap guys are doing, some put it in the boot, others go for the space under the arm rest and yep hook straight into the aux socket from behind, some ive seen even rewire the component plugs in the center console to the av input on their new tv tuner.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
