hey guys
ive got a 94 gtst r33 manuel, current mods are 3 inch turbo back exhuast, fmic, greddy e manage, pod filter, turbo smart dual stage boost controller, car is roughly 215-220 kilwatt at 14 psi (standard turbo).
i would like to get another 10-15 kilawatts if possible by maintaining the same amount of boost (14)psi
i have mentioned to my mechanic about gettin either injectors, fuel pump, or getting the additional injector and ignition harness for the e manage, but hes advised that itll be a waste of money, and that my next mod would have to be a turbo upgrade, but i dont really want to spend more than $800 on parts right now,
also do splitfire coil packs give more power?
any comments would be greatly appreciated
Coilpacks definitely give noticeable power if your originals are f**ked. Otherwise you wont feel anything, they make it smoother n more responsive just like new plugs.
Edited by rondofj
<br />New turbo or E85 + re-tune.<br />
<br /><br /><br />
Only problem with the 2nd half of this idea is that there probably isn't enough capacity left in the std injectors to make the power on E85.
As to the original question.....there's not a lot left in your turbo. You're already running it past the point (boost wise) where you can expect it to crap itself at some (unpredictable) time.
The only way you will make more power now is with bigger injectors, pump and retune on e85 if you wont upgrade the turbo.
If your car is making that power, regardless if people say its a happy dyno, you will be maxing out the stock fuelpump and injectors, so adding an extra one wont help if the pump is alreay maxxed out.
Seeing as you dont want to spend any money im not sure how your going to achieve this.
Coilpacks will be $600+ for Splitfires, injectors dont come cheap, then the fuel pump.. then a retune.
I say save your coins and upgrade it when you can afford it.
I would also find a new mechanic mate cos sounds like he dont know WTF he is talking about because with out bigger injectors and fuel pump a bigger turbo is useless to you! if you wanna do it cheap buy a 2nd hand GTR fuel pump and some SR20 injectors highflow ya turbs get it retuned if ya shop around and get lucky you MIGHT get some change from $2500 and you will be good for 250kw :thumbsup:
Stock injectors will do ~230kw max safely
But yeah your turbo is out of flow so the only way to make more power is either bigger turbo, or run E85 so you can wind more ignition timing in, stock injectors prob won't flow enough though.
Next step is $4k really as you need airflow meter, injectors, turbo, fuel pump, most likely coilpacks, then clutch, then tyres, then a full retune regardless of if you want 230kw or 300kw
If you already have enough fuel, eg injectors are not maxed out and nor is fuel pump, then putting bigger injectors in will just require a retune for zero gain, bigger fuel pump is probably not a bad idea but it won't give any extra performance, will just give you some extra safety and if you decide to use E85 down the track it will give you the required flow.
If you are maxing your injectors out the car will lean out and probably make slightly more power but pop the engine. Only replace them if you require extra fuel flow, eg a bigger turbo, as it will require a complete retune which is $$$
honestly your car is not making 220rwkw - more like 190-200 MAX.
this is what literally hundereds of users on here have found, the only way to get that far on a stock turbo and 98octane is a happy dyno.
for around $800 you could find a second hand highflowed turbo. throw this in and you can get to roughly ~230rwkw (that's a real 230rwkw though) so roughly a 15% gain.
throw injectors, afm and fuel pump at it and you can look at more around the 250rwkw figure.
this is not the best method, however it is the cheapest :)
also as rolls said you will need a clutch... probably want to shim your diff too
14PSI will not last very long on a stock turbo either. Do a search "r33 turbo max boost".
Stock Inj + bump the fuel pressure will get you a tad more power (whatever the number on the dyno reads)
After that you can throw what ever turbo you like at is, no more power. Your tuner is telling you turbo and rightly so. The stock turbo will not
last long at 14PSI. Do you want to be cleaning comp housing shards (yes yes the rear blows out, but it unbalances the shaft and the comp wheels generally grinds a nice path up against the comp housing) out of your intercooler?!?!
So basically you need to do all four, turbo, inj, pump and afm.
Also whats up the with e-manage? Just asking seeing 90% of the population use PFC, the other haltech, link, vipec etc.
Buy this bad boy and max re-tune it on the stock pump and injectors. It may cost a lil more than $800 but ur more than likely up for a new turbo sooner than later running 14psi on ur stock one
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Cover-T3-8cm-V-Band-Housing-TD06H-20G-/290651769905?pt=AU_Car_Parts_Accessories&hash=item43ac320c31#ht_2744wt_1396
Its on sale at the moment.
my car dynoed at 220 rear wheel kilawatts when it was auto @ 14psi, by initial d racing,
auto should read lower anyway... so that result is even more inflated... there is NO WAY your car makes a genuine 220rwkw on the stock turbo. the lil turbo simply cant flow enough to make those numbers and there have been HUNDREDS of cars on here that prove that.
i wasn't trying to insult you, i was being positive, saying that if you get a genuine 230rwkw it will be 30 - 40 rwkw faster than what you have now, not just 10.
fwiw my car made 185rwkw with the stock turbo on 14psi running the same (ish) mods and a pfc. most people get around the 190rwkw mark.
also stick to around 12 psi. the stock turbo is out of puff then anyway. by going to ~14 or above you really are only squeezing like 5kw out of the engine for a LOT of stress on the ceramic exhaust wheel.
emanage is fine for up to around 250rwkw. according to trent who used to specialise in them there is great gain in upgrading past one unless you are planning on 250+
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
