Hey guys,
After a long time thinking about the direction in cars I want to head in, I have sadly decided to sell my very first skyline.
I am the first owner of this car in Australia, purchased it in October 2008 completely stock from Kamikaze Motors.
I have purchased all the parts myself and had all mods installed by Le Mans Automotive in Templestowe.
Serviced every 5000KMs
1996 - ECR33 - GTS-T - RB25DET - Manual
141K on the clock
AR1 - Super Clean Red II / Nismo Racing Red
Factory Sunroof
Tein Mono-flex Coilovers
Hel Braided Brake Lines
DBA 4000 Front Rotors
Project Mu B-Spec Front Brake Pads
Project Mu Shims
Greddy Oil Filter
ARK Rev Shift Timer
ARK Advanced Boost Controller
Blitz FMIC - Return Flow CS
JJR 3" Bellmouth Front Pipe
X-Force 3" Stainless High Flow Cat
JJR Rear Strut Brace
Front Strut Brace - unknown brand came on car
JJR Hicas Lock Bar
O2 Sensor Replaced 10,000KMs ago
Autometer Boost Guage
Wed Kranze ERM 17" x 8.5" gtr offset 2.5" dish
Yokahama S-Drive Tyres
Sony CDX-GT170 black/red Headunit
Pioneer Carrozzeria Tweeters
Pioneer Carrozzeria 6" front speakers
Sony Xplod 6" 4 way rear speakers
Sony Xplod XM1S Amp
Sony Xpod boxed subwoofer with grille
Replaced windscreen 10000KMs
+Few other parts here and there
I will also be including
APEXi pod - used for 1000KMs
Nismo front lip - in silver
Series 2 optional black mesh grille with red S
collection of shift knobs
Stock R33 Wheels x4
Stock SMIC, brake lines, front pipe, cat, shims etc
I have receipts for everything and these are available for perusal
The car has never been to the track and boost never pushed above 8psi
seats always covered with seat covers
car has a small dint on bonnet, could probably be popped out very easily, and a 50 cent coin sized chip of paint off the front bar from someone reversing into me
im asking for $9750 ONO
Send through a private message if you have any questions
Thanks
post-55700-0-19494500-1327129819_thumb.jpgpost-55700-0-58323800-1327129871_thumb.jpgpost-55700-0-67688400-1327129881_thumb.jpgpost-55700-0-92484000-1327129898_thumb.jpg
Edited by bluejeans
https://www.sau.com.au/forums/topic/388959-r33-gtst-series-2/
  • 1 month later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
