Hey guys!
I recently purchased a R32 GTS-T with no compliance plates for a cheap price, the car runs beautiful, but i'm a bit concerned. I took it for a fairly decent drive today (Illegally, shhhhh :P) to see how it ran, All the gears are fine, oil meter was fine, temp was fine. It definitely has power, turbo kicks in nicely and haven't noticed a problem with it. The car has had the idle problem but the previous owner "Fixed" it, so it'll idle at around 1.5 constant. But my main concern is the blueish smoke that comes out of the exhaust after letting off the accelerator while idling, as far as I'm aware it doesn't smoke when driving, but then again I'm not behind the car to confirm it fully. The blue smoke says to me, OIL!! It does leak a bit of oil from somewhere but not sure where abouts YET, although it's around the general area of turbo/power steering.
Could this be fried piston rings? or something a bit simpler. I'm only eighteen with no previous engine building experience but would love to take the engine out and rebuild it just to confirm my suspicions/nice learning curve.
Any help will be greatly appreciated!
Thanks, Braden!
https://www.sau.com.au/forums/topic/388975-blue-smoke-eek/
Whilst mate is following your car at night, the blue smoke is constant if it's a rings problem.
If there's more smoke coming out under boost, then turbo seals are suss as well; not forgetting valve seals.
Comp test says what?
Oil useage going up?
https://www.sau.com.au/forums/topic/388975-blue-smoke-eek/#findComment-6199003
I might setup my camera and test this as I won't be able to get a chance to drive it illegally for a while. But I do know that when I have the car sitting and I rev it, after I take the foot off the smoke comes out, can't see any if i'm holding a constant rev.
If it's coming out while driving aswell it could be
Rings
Valve seals
Or turbo seals
How much oils in the car it could be over full
Well I think the meter on the dash was at 4
https://www.sau.com.au/forums/topic/388975-blue-smoke-eek/#findComment-6199021
Okay so I went out just then and started her up, let it warm up. The oil sat at just under "4" on the dash, I checked the actual dip and it was like half way up the stick, also had my brother rev it at a stable amount and there is no smoke today, not even when I let off the accelerator..
https://www.sau.com.au/forums/topic/388975-blue-smoke-eek/#findComment-6199023
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
