hey guys. im urged to buy another gtr, so i have put up for sale my jeep srt8 or possibly swap for a r34 gt-r. these suv's come standard with 317kw. they come with a 6.1L hemi v8 which sounds and goes very tough for a suv.
it has 77,000kms and is in excellent condition, my wife drives the car mostly so it definately hasnt had a hard time. heres the specs:
fully integrated sound system which includes bluetooth, dvd, navigation with updated software,usb,ipod interface, tv, reverse camera, and lots more extras. great additonal option which is rare on all jeeps.
arrington cold air intake kit. imported from america which costs a fortune made from carbon fibre.
cross drilled and slotted brembo brakes. with stoptech pro brake pads, fitted 2000kms.
also has a jeep customised towbar which fits neatly on top of the exhausts. great for towing all sorts of trailers.. but never been towed before.
heated seats
rear parking sensors
leather/suede trim.
this car is fantastic to drive. the sound system which includes the parking sensors and reverse camera are a jeep extra. excellent for those tight spots, the camera shows a wide angle to safely reverse park and see all thats behind you. performance wise, exhaust is very quiet up until you open the throttle and hold on to your panties. it is shockingly quick.. and now with the brake setup it stops as hard as it goes. very responsive and with the cold air intake sucking in cold air it not only goes better but sounds like a true hemi v8 should! my wife drives this car 90% of the time so it has not been abused. washed weekly and is very well maintained.
my wife most of the time to work only (10 min from home) kept in a garage and undercover wherever it goes. it has just been serviced and also done the spark plugs with platinum spark plugs. everything used on the car is top of the line gear.
all performance parts were bought from the usa. and only the best brakepads/brake discs were used. also the arrington cold air intake is the most expensive and best on the market for the jeep srt-8. excellent performance parts which helped the car perform and breathe more cleaner air with a small percentage of fuel consumption savings.
this is a really really fast suv. 6.1 hemi v8 are not your average v8 motors. its a sling shot off the line. im really impressed with how they have balanced this badboy..
price is $45000 Or swaps for a r34 gt-r, possible trade with a evo 9. or cars with similar value.. my number is 0410158440 car is located at burwood, nsw.
thanks guys.
Edited by Rami_G
crazy car man
i work at jeep and have driven a couple of these they r very fun and i luv the sound they make!
cant wait for 2012 model to come out with the 6.4litre engine in it
  • 4 weeks later...
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
