Hey guys
I have for sale 2x nismo calibrated AFM's, they have been cleaned, serviced and recalibrated by Australian fuel Injection http://www.afiaustralia.com.au/home
basic run down of my situation is i had these AFM's (before recalibration) on my old set up before my engine dropped compression in one of the cylinders. I decided to go all out and chase some big hp figures so i had my afm's sent away to be recalibrated. This allows for greater power potential/tunablitly over the standard AFMs while maintaing a stock look as they bolt straight back into standard plumbing whilst keeping standard plugs. Reason for selling them is ive decided to go a different direction with my build. Ive recently purchased a LINK ecu that does not require AFM's so as u can see i no longer have a need for them
This is a far cheaper option then buying nismo afms, and a lot less stuffing around then buying z32 afms that require modified plugs and plumbing to make them fit.
http://www.ebay.com.au/itm/Nismo-Mines-RB26-GTR-Air-Flow-Meters-recalibration-/120491260709
as you can see from the link above it costs $275 per afm to be calibrated + cost of shipping to have them sent there and back.. all up over $570. They came with a 12 month warrenty which has now expired as i had them done at the end of 2010, but since then they have been sitting in the boxes they came in and havent been used so they ar good to go
Im chasing $450 dollars for both of them, this includes shipping to anywhere in Aus so as u can see im a a bit of a loss here.
reason for selling them this much cheaper is
1 i need cash to fund the new set up
2 a corner of one of the afms has broken off so now it has 3 mounting bolts as appose to 4. This hasnt effected the performance of the afm's on the previous set up, nor should it affect it now, mesh is still in good condition (pics included)
as stated above i havent had the chance to use them yet so if they were not to perform as expected i would be more then happy to refund the full amount minus the shipping costs. (check my trader rating as its all 100% positive)
Located Sydney
contact number is 0432528844 or PM me
:cheers:
https://www.sau.com.au/forums/topic/389023-fs-nismo-calibrated-afm-x2/
These ones are direct bolt in because theyre just the stock ones but recalibrated to nismo specs
the z32s dont bolt right in either, they have different size flanges and u need to change the plug
found a link on it
http://www.skylinesaustralia.com/forums/topic/57632-nismo-afms-for-gtr/page__p__1110524__hl__nismo+vs+z32+afms__fromsearch__1#entry1110524
z32's are also larger so nothing mates up, they are 80mm vs the GTR stock ones of 65mm
the preferred upgrade path when you max the stockers is the nismo 65mm AFMs
they are z32s internals inside a GTR afm shell so everything mates up
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
