3Rd Annual Pre-Powercruise Dyno Day 18.02.12 Newcastle
Copied from another forum thanks :thumbsup:
It's that time again. The 3rd annual PRE-POWERCRUISE dyno day will be held Saturday the 18th of February
Will kick off at 8:30am at 4b ACTION Mitchell st Cardiff.
Come down and run your car so you know every thing is running sweet before you flog the car for 3 days at the big event. Or just come down to see what other cars make
Categories
4 cyl N/A - 4 cyl forced
6 cyl N/A - 6 cyl forced
8 cyl N/A - 8 cyl forced
FWD
HP per litre
Highest HP overall
Encouragement award
The dyno is a DYNO DYNAMIC 2WD dyno ( sorry all you AWD people)
There will be a trade stands from AUTOBAHN with all your performance parts and car care specials for sale, and a BBQ going all day.
Price is $60 for 3 power run and a print out of hp,kw,AFR,boost etc and a free sausage sizzle and can of drink
Please check your water and oil levels are topped up before your car gets run up
Hope to see every one there
Link to Facebook page
http://www.facebook....25744700793397/
best bet to get in and pay your money early they only have 50 spots.
  • 4 weeks later...
I was the first up on the Dyno managed a 190rwkw at 13psi untuned with healthy afr's so was pretty happy, specially since my first Dyno run at hunter awd dyno was 130kw :(Was good to see some other skylines, majority were r32's even 1 running a 1jz, good day for along as I was there. A few common skyline problems managed to find themselves but I think faulty coils may be the cause of a low reading for a weapon of a 34,and rb20's with a little heat soak. Other Cars were a decent amount of v8 utes, a few Silvia boys and xr6t with 350kw boiling coolant , which was cool to see in the overflow. Big thanks to the boys, even allowing me to run shotgun to pump some more boost in :) hope some people got photos.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
