i have been wanting to make these but no-one seems to have any roof racks laying around that i could use to mold from
if there is a wrecked car in sa maybe i could come to an agreement with the owner
Edited by Fgjoh
Actually what I'll do is if i can have a show of hands for the C34 drivers enclosure
I can get an idea of the demand and possibly get a good mate to step in and finish the plug and mold
Post your forum name and repost in the list below
1. Zombie_drifter
2.
3.
4.
5.
6.
7.
etc
cheers,
Pete
p.s M35 is on the cards but as the weather has been quite shite lately this makes building the proto difficult, As soon as it warms up it'll be done ASAP Bigkevracer has put his hand up to be the guineapig for the proto
fair enough..anyways id be keen as if/when u ever get to
making them,as would most stag owners id say
  • 1 month later...
  • 3 months later...
  • 4 weeks later...
Looking for passenger side sub enclosure, and drivers side as well, if available. Will need to be freighted to Mudgeeraba, 4213.
Cheers.
  • 3 weeks later...
I saw Fgoh the other day, hes flat out with a new job, i woudn't be suprised if he didn't make anymore stuff
by the sounds of it(not that i want to put words in his mouth)
All the stuff i got was the last stuff he made and that was a long time ago
cheers
darren
Thanks Jet
yeah i have been flat out with work it's only getting worse too
I can't seem to keep up with fiberglassing and work
so i may just take a job here and there
although eta's will be around the 2+week mark if any work is taken on
If you do want something pm me and i'll try to get back to you asap
Hey Mate,
Its been a month since you told me you would post my gauge pod "later this week"
Yet I have still received nothing and no reply to my inboxes, Whats going on?
