Hi everybody,
I was at Oran Park yesterday for the latest GTP (or whatever it's now called) round. As well as the usual feast, there was a drift demo - and it was wayyy cool. S14's, s15's, 180's, Hachi's, an MX-5 and even a Monaro; they all put on a great show. Very popular with the kids. The trackside commentator was very well informed on the sport as well, dropping words like hachi roku, linking & giving an accurate assessment on the history of the sport & D1. He also mentioned that D1 competitors will be making an appearance at Oran Park later this year !
Does anyone have more info on this ?
Thanks.
https://www.sau.com.au/forums/topic/38908-dori-oran-park/
Hi Matt,
Thankyou & your crew for putting on such a great show. I love the GTP series as it's so relevant to the cars we drive - even more so with drift. I was at the dogleg & believe me you guys had everyone on their feet (more so than Nations cup/F3/V8Brutes) "Dad, are the drifters up next ???" the kids around me were repeating all afternoon. I have committed myself to getting a CAMS licence this year so... I better get myself some stiff coilovers & raid my local tyre joint's scrap pile. I think drift will put that silly grin back on my face that I've been missing for too long !
https://www.sau.com.au/forums/topic/38908-dori-oran-park/#findComment-790645
I was out there in the purple 180SX.
...I was at the dogleg & believe me you guys had everyone on their feet...
The dogleg was the craziest corner I reckon, since you can't see what the heck is over the hill, and a lot of us spun out coming down the other side.
The one time I actually had a chance to look at the crowd, I saw a bunch of kids almost hanging over the fence, hooting and pumping their fists. Heehee.
https://www.sau.com.au/forums/topic/38908-dori-oran-park/#findComment-794760
Yeah fatz called me on the thursday and said to come down and burn some rubber, but I had my engagement party on that Sunday... and suprising the missus said no??? go figure!
I have been speeking with Yokohama about drifting recently as they got my name from my tyre supplier and gave me a call. They want to get involved in drift and wanted to know more about it. I believe that they are looking to bring at least the Drift King and his car out from Japan towards the end of the year... keep your eyes peeled on here and on initial drift site as once I know more hopefully the two clubs will be able to put on a huge day for this major drifting event... I'm excited!
Dan.
https://www.sau.com.au/forums/topic/38908-dori-oran-park/#findComment-796383
Dan.
Really? Did I mention how much I just LOVE Yokohama tyres?
Did I also mention that I won 2 of the 3 CAMS-sanctioned drift competitions in NSW so far? .....and how much I just LUUUURRRVE Yokohama tyres? :mad::rofl:
https://www.sau.com.au/forums/topic/38908-dori-oran-park/#findComment-797581
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
