youve not given much info . . . does the stock pipe not fit? is it a pipe or hose that your after? if its a pipe that you require and the stocker dont fit then you need to contact the person/company that sold you the aftermarket manifold
https://www.sau.com.au/forums/topic/389152-coolant-pipe/#findComment-6202272
seeing as you already have the stock intake off the car you should be able to work out how its attached ,ive just looked at a stock R33 S1 25 intake that i have in my shed and its bolted to the manifold-coolant goes thru the manifold AND if ive looked at it properly (bit dark in there) , thru the idle air control
https://www.sau.com.au/forums/topic/389152-coolant-pipe/#findComment-6202777
