  • Replies 219
Posted Images
umm I'm sure he had an option to buy a car that was not turbo or 8cyl. pretty simple right? people taking the piss on laws (or thinking because they are famous or have money that they can ignore them) are exactly what makes it so much harder for normal people.
for every wanker like that, the rest of us have to work 10x harder at being good
A choice between an M3 and a 320i..... lol
Sorry Duncan but your on your own with this one.
The law says he can drive it
Plenty of people on the forums get exemptions for Nissan turbo cars, why should it be different just because he is famous and drives an M3?
Personally I think he is a cock head, should have gone home after the first run in, guess time will tell if he was in the right or wrong, but for all we know he could have been caught the second time comming back from an hour at the courts (his work) to let off some steam after the first incident... I recon his father is guiding him wrong though, usually is the case with young sports stars.
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
