looking to get some adjustable arms for the R, prob just camber but may considering other things like caster as well etc
last time i had an alignment done, they said it was around -2.5 all around, which they said is about where they would want it anyway but i'm thinking of reducing that a bit for street duties and to save the tyres a bit, then change for track days (don't do many, so alignment costs are too bad)
i think the car has some R33 GTR sus parts, LCA from memory, but can't remember exactly. Need to check the specs list again :D
Cusco arms :)
Racepace modify them if you wanna get more serious with adjustments
Or you can have the factory ones modified as well but not as much freedom as Cusco ones.
Depends how much/what you want i guess.
  • 6 months later...
ok. bringing this back to make a decision on which arms to get. Once i've sussed this out, i think i might get some bolton spacers to get the stance bang on - 10.5 +15 just don't cut it on a 34 R
and do i only need to do 'upper' arms front and rear? i wouldn't want to be changing camber from a lower arm? (if you can even do that...)
Ok, so options seem to be...
Driftworks:
Front (~$250)- http://www.driftworks.com/shop/r33-and-r34-nissan-skyline-front-upper-camber-arms.html
Rear (~$170)- http://www.driftworks.com/shop/driftworks-camber-arms-s14-s15-r33.html
not really feeling the orange :D but i've heard good things over at gtr.co.uk as well - they do a full R34 GTR kit as well for $700 odd.
Hardrace:
For some reason, i don't think they do front arms?? can't seem to find any for a 34
Rear ($175) - http://www.hard-race.com.au/index.php?route=product/product&path=25_32&product_id=217
SRI (found these when looking through the Just Jap site)
Front ($220) - http://justjap.com/store/product.php?productid=17665&cat=396&page=2
Rear ($149) - http://justjap.com/store/product.php?productid=16598&cat=396&page=3
Ikeya Formula:
Front (~438) - http://www.nengun.com/ikeya-formula/front-upper-link
Rear (~$390) - http://www.rhdjapan.com/ikeya-formula-rear-camber-adjuster-upper-arm-set-nissan-26495
why does the Nengun rear upper arm pic look different? http://www.nengun.com/ikeya-formula/rear-upper-arms
Kazama AUTO:
Rear (~420) - http://www.rhdjapan.com/kazama-auto-rear-upper-arm-nissan-58403
Can't find link for front
Cusco:
Front ($314) - http://www.nengun.com/cusco/adjustable-front-upper-arms
Rear ($376) - http://www.nengun.com/cusco/adjustable-rear-upper-arms
So as per normal, the Jap stuff is a lot more $$. I take it i want to be getting pillow ball arms?
Should i just grab something local (Hardrace etc) or fork out for the Jap stuff? Is there actually any difference between the Jap parts and the cheaper "aussie" stuff?
As usual, my 2c is that pillowball arms are defectable. The few arms that are available with rubber bushes won't maintain geometry as well, but will be better than original bushes (they're harder rubber). Just depends on what's important to you. I'd prefer not to have a big issue if there was a crash/accident and the insurance co got pissy. Suspension arms are the sort of thing that is easy to point a finger at and blame.
ahhh... interesting... this i did not know....
i'm not particularly fussed about legalities and i don't do many km's, so hopefully wear and tear won't be so much of an issue. Why exactly are they supposedly more dangerous than rubber bushes?
there a difference between rose-jointed and pillowball? looks like i've got a bit of both going on...
BCNR33 Front Lower Control Arms
MIDORI Development Pillow ball tension rods (castor rods – rose jointed)
NISMO reinforced Upper link/Upper Control Arm Bushes
MIDORI development Rear Pillow Ball Upper Links bush replacement (rose
joint bushes in upper control arms)
MIDORI Lower Arm Pillow ball bush replacement
MIDORI rear sub-frame collars
NISMO upgraded rear sub-frame bushes
Driftworks:
Hardrace:
Ikeya Formula:
Kazama AUTO:
Cusco:
I have the complete driftworks arm set in my drift car snd im happy with the items been in for about 18months now.
Slso yes you only need the upper arms, the adj lca are for adding more track which can also be used if you dont want to use spacers.
I put the cusco ones on the front of my 34, I brought them cause they are blue like the car, no I'm not kidding :P
easy to fit and appear to be good quality and with a small mod they have heaps of preset adjustments
only thing I think is they are not so good if you want to adjust the castor though as the are a fixed 1 piece arm with a bolt holding it to hub assembly not a ball joint
i am leaning in the Cusco direction. 1) seem to be the cheapest of the Jap stuff and... 2) like you said, there seems to be a modification option with them that Ash mentioned as well, and given that my mechanical work is done by Racepace, i've got someone who's done it before...
considering all the other suspension work done on the car... i wonder why Midori didn't put in adjustable upper arms for camber changes? it's almost if they did it all, found camber to be 'x' and said, yep, that's fine, no need for adjustments. But -2.5 all around is a bit much for a predominantly street driven car i would have thought...
Yeah Racepace mod the Cusco ones for the circuit cars, but then depends if it's "really" needed. I did ok with stock modified ones as it wasn't too aggressive and even then still managed to wear tyres (should've rotated more often).
Comes back to what you are doing with the car mate. If you are going to live on the circuit then yeah go Cusco ones and get them modded etc. If not I'd honestly recommend to save the cash and stick with modified stock ones based on my experiences.
I'm sure extra geometry would've helped when on the track, but really another 1-2 years of experience would've offered much more benefit hence i stuck with stocker/mod :)
in terms of changing camber settings though, Racepace stock-mod vs Cusco - isn't it easier to change the Cusco? (not knowing exactly what is involved in the Racepace mod)
not to mention they flog out rather quickly
Meh. ALL my Ikeya arms are pillow balls and some have been in there for almost 4 years. They're fine.
People make out like they flog out in 100 km's. As for noise.... Can't hear nothing!
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
