R34 Gtr Owners, What Adjustable Arms Are You Using?
Meh. ALL my Ikeya arms are pillow balls and some have been in there for almost 4 years. They're fine.
People make out like they flog out in 100 km's. As for noise.... Can't hear nothing!
Your car has only seen 2 full days of driving time haha
But 20 years for rubber vs less than 10 for rose joints or less again for cheap shit ones
Shhh, can't tell people :P. They are never on hand and always have to wait and order em in.
I have the castor bush kit with an offset pin for more caster, so i get to keep the light aluminum lower arms.
Whitle front and rear adjustable sway bars, and I just ordered the rear swaybar bearing link kit to go with it.
My 32GTR had whiteline sway bars too, and their camber correction bush kits. 6 years of use and the bushes were fine.
Whats wrong with whiteline? no ones mentioned whiteline except for sean.
I dont think whiteline do actual adj arms , they only have the adj bushes from what I have seen and those bushes are fine if you only want to make very slight adjustments as there is not much in them.
Yuh, Whiteline bush kits are nearly useless for gaining adjustment more than about 0.5 degree (depending on which arm we're talking about). In addition, I replaced my original front caster arms that were fitted with Whiteline polyurethane bushes with some rose jointed adjustables. Even without winding in any more caster the car improved massively just because the squishability of the bushes was gone. Those caster bushes take a lot of force, and they do move a lot.
From the whiteline website:
http://www.whiteline.com.au/do_segue4.php?make=Nissan&model=Skyline&model_final=SKYLINE+R34+GTR+AWD&vehicle=11%2F98-02
Part numbers:
KTA 128
KTA117
Those are the one's I plan to use....
  • 2 months later...
just an update...
pulled trigger on a set of Cusco arms front and rear. Perfect fit (as expected) no farking around, but some issues though.... can't seem to run less than -3 camber no the front :( - rear is set about -1 which is about right for street for me, but as much as the turn-in is freaking nice with the current setup, i got adjustable arms hoping i could run street'ish camber and cranking some more neg in when needed.
is this normal for cusco arms? are they just that much shorter that you can't actually get 'a little' camber? i was kinda thinking like -1.5. on the fronts....
it's low but not that low, and the suspension place said the same thing. It looks low'ish but in terms of geometry etc it's THAT low... that's why i'm a little confused.... - if anything, i'd probably want to drop it some more
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
